Results 1 to 5 of 5
    Default GB made battery worse?
    After updating to GB last night my battery usage reads:
    8 hours and 44 minutes
    Phone idle 52%
    Display 16%
    Cell Standby 10%
    Mediaserver 8%
    Pandora 7%
    Android OS 4%
    I have 50% of my battery left. That means my phone being idle used over 25% of my battery in 9 hours. That seems like way to much. Any suggestions.
  2. #2
    Default Re: GB made battery worse?
    After updating to the rooted version of GB my battery lasts longer than it did in Froyo. I have seen people post other places about battery life... some good... some bad. I think it may have to do with what you have running on your phone.
  3. #3
    rcodey's Avatar
    Posts
    Global Posts
    18 Global Posts
    My battery drain appears worse with new software.
  4. #4
    Yeah my phone idle statistic is way up. I'll have to keep an eye out on it though, because it does seem like it's taking more battery life overall.
  5. #5
    Just wondering if anyone has figured anythign else out about this. I'm also getting a much higher "phone idle" portion of my battery drain after GB update. IN my case, over 25% and the #1 consumer of battery power. Used to alway be "display".
