Results 1 to 11 of 11
    Default weird audio issues... is my phone possessed?
    So as of late my phone has been doing weird things while playing music through the audio jack. Initially I was having issues with the stock player randomly quit playing and then when I would try to resume playing it would be the beginning of the track. I then tried using playerpro which solved the problem for awhile but then a new problem randomly started. I would be listening to something and the screen would come on by itself and start playing something completely different and then turn shuffle on automatically. Got sick of that, so deleted it and went back to stock. Then a new problem, as I'm listening to music it opens a streaming radio app and starts playing it over what I'm already listening to. So I delete the streaming app. Now it just started bringing up the google voice command prompt. And just as I'm writing this, I have my music paused, headphones in, and the voice command came up. It seemed to pop up when I bumped the headphone jack, could this be some sort of hardware malfunction? It does seem like the jack on my phone is sensitive to any type of movement, as in you can hear static if it's bumped.... Thanks for any help on this!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: weird audio issues... is my phone possessed?
    Wow, that's really weird. I'm not necessarily suggesting this, but, have you done a factory reset? I think that'd pretty much boil it down to a hardware or software issue, ya know?
    Ya I think I may try that next... I really have a suspicion it's something with the jack now because I noticed it happening again multiple times if it was barely bumped. But if I go ahead and do the reset and it doesn't fix it, I can take it into Verizon and get a new phone.
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by ripewithdecay View Post
    Not really sure that it'll have anything to do with the jack. Sounds like the phone just might be messed up. Did you do a reset? Did it fix it?
    I did do the reset today. Tomorrow will be the big test though because I use it for about 12 hours while working. I will post back if it fixed the problem.
  6. #6
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Cool man, good luck. Look forward to hearing your results.
    Hah well no dice, the voice command prompt still pops up, and it did something even crazier. It started playing super fast, like chipmunk voice. I tried different songs and still played super fast, even with my headphones unplugged it continued playing crazy thru the speaker and then randomly called someone too. I think I may just have to take it : /
  8. #8
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Haha, that is hilarious. What a buggy phone. Never heard of anything like that. Especially strange that the factory reset didn't fix it. Good luck taking it back and getting your new phone!!
    haha I know, when it started playing super fast I couldn't help but laugh... anyways, thanks for the advice man.
  10. #10
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    You're welcome!! Although, I didn't really help much, I just tried. Not really much we could do with this one.
  11. #11
    Weird Man my icons doing the same thing but not the chipmunk part yet...... And its driving me crazy plz send me an email at or if u find a fix for this GOD I don't wanna have to do a factory reset
