Results 1 to 4 of 4
    jtornone's Avatar
    Posts
    Global Posts
    28 Global Posts
    Smile Droid X2 Replacement
    Ive been working with Verizon tech support to get my phones working with my network extender. Its going on 2 months now, and Verison support is now contacting Samsung to see what the problem can be. If this dosnt work, they said next possible step would be to change our phones. I doubt they will give is 4G phones, so what are your recomendations for a good 3G replacement that is not a motorola since the tech told me they have had problems with some motorolla phones working with the extendor.
    I was looking at the Inctedible 2 but it only has 1.2 gb of internal storage, but does have more ram and is unlockable. Any sugestions would be greatly appreciated. Thanks.
    John T
  2. #2
    Default Re: Droid X2 Replacement
    Could go with the LG spectrum has 8gb of internal storage or the LG strataphere or the htc rezound I would check out the rezound just cause to me personally it seems to be a better phone memory wise. But the choice is yours just giving my opinion if anything u could maybe get an iPhone haven't heard to many complaints about them but then again I don't know a lot of people who use them so that could be a clue.
    jtornone's Avatar
    Posts
    Global Posts
    28 Global Posts
    Just incase anyone is wondering, after 3 days and 9 hours of a 3way conference call with me, Verizon, and Samsung I finally got Verizon to replace the X2's. They are giving us 2 HTC Rerounds. I'm very happy with what they are giving us. Cant wait to recieve them.
  4. #4
    live4spd's Avatar
    Posts
    Global Posts
    210 Global Posts
    Default
    Curious does your X2 drop calls while you are on the network extender?
