Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Chipmunk
    bbsadaj's Avatar
    Posts
    Global Posts
    781 Global Posts
    Talking Settings for the notification light
    Is there settings for the notification light on the X2? Just curious is all, made the switch from blackberry and if there isn't i might have to switch back.......not a chance in hell, haaaa!
  2. #2
    Default
    i actually played around with this the other day, didn't find anything on the phone, and tried a few free apps. none did anything. i think being rooted could change that though, really depends on the type of LED in there, i don't know if its just the green or multicolor, haven't seen anything but green show on mine so far.
  3. #3
    heggood's Avatar
    Posts
    Global Posts
    143 Global Posts
    Default
    2 of my apps have settings for various different colors, so I have different colors set for email, text (handcent app), messenger (whatsapp app).
    Thanked by:
    Qmagic
  4. #4
    Default
    I've downloaded Blink from the market and it let's me set notification lights. It only has 5 color options but im sure the dx2 can do more colors.
    cynbad#AC likes this.
  5. #5
    mikey95gt's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default
    I too came from a blackberry. I use Light Flow to created different LED light colors, plus it will do different vibrations. It seemed to be close to the customizable blackberry notifications, but better as the LED and app has more colors.
    Thanked by:
  6. #6
    Default Re: Settings for the notification light
    Quote Originally Posted by grabermike View Post
    How did you get it to blink, I have light flow but it still does not blink.....Thanks
  7. #7
    mikey95gt's Avatar
    Posts
    Global Posts
    59 Global Posts
    Quote Originally Posted by tennislvr8 View Post
    LightFlow App - General Settings - LED flash rate. It will only use the LED when the screen is turned off also, which is different from the blackberry.
  8. Thread Author  Thread Author    #8
    bbsadaj's Avatar
    Posts
    Global Posts
    781 Global Posts
    thanks for the info.
