Results 1 to 4 of 4
    Default Spare battery for the Droid?
    If i buy a spare battery from AC store it doesnt come w. a charger so i can just charge the battery? If thats is the case then wich battery and charger should I buy???
  2. #2
    Default
    I bought one of these to charge the battery and my phone
  3. #3
    azjerry's Avatar
    Posts
    Global Posts
    295 Global Posts
    Default
    Doesn't look like the Amzer will work with the hard case on my Droid. :^(
  4. #4
    Default
    Motorola also sells an external battery charger for $20.
