Results 1 to 5 of 5
    gehx's Avatar
    Posts
    Global Posts
    55 Global Posts
    Default pairing problem w/ Plantronics Discovery 975
    I'm trying to pair a Plantronics Discovery 975 w/ the droid, but the droid can't discovery it....not sure what to do...i've used this headset w/ my storm w/o any problems....anyone else experiencing this?
  2. #2
    Default
    I have the Plantronics 925 and it works perfectly. I hate to say it but it might be user error. You said you used it before so I'm sure you know what you're doing. Other than that, I would just try again.
  3. #3
    Default
    I recently purchased the Plantronics Discovery 975 and it pairs okay, but I can't get it to connect. Any ideas?
  4. #4
    yasuro's Avatar
    Posts
    Global Posts
    28 Global Posts
    Default
    Quote Originally Posted by 9strings View Post
    same here with my plantronics voyager pro. it works great with my other phone, but it shows paired but not connected with my droid. i have to repair to get it to work, but it won't connect if i turn off bluetooth and turn it on or if i turn off my headset and turn it back on.
  5. #5
    Default
    Another plantronics voyager pro - Droid Incredible non-pairing issue here. I already tried:
    1. Deleting the pair of the Pro from my old phone;
    2. Turning off both devices
    3. Turning Off wi-fi
    4. Trying to reset the voyager pro (although, honestly, I can't find a definitive direction on resetting the Pro -- except to hold the volume + and call buttons simultaneously)
    Short of scrapping the $100 investment in the Pro... HELLLLLP!
