Results 1 to 5 of 5
    Lurch81#AC's Avatar
    Posts
    Global Posts
    1,135 Global Posts
    Carrier
    stock
    Default Am i using wifi or not?
    Ok i know this is probly a dumb question but i turn wifi on connect to my home network and the wifi signal shows up but how do i know if i am using wifi or verizon's network? its not like when you turn wifi on 3g goes away.
  2. #2
    GenericMessage
    GenericMessage's Avatar
    Guest
    Default
    Quote Originally Posted by Lurch81 View Post
    If the wifi signal bar is up with your other status icons
    Just make sure it doesn't have a question-mark next to it
  3. #3
    Jared DiPane's Avatar
    Posts
    Global Posts
    7,367 Global Posts
    Carrier
    Stock
    Default
    As long as you have that wifi icon up there working, then you are utilizing that instead of the Verizon data network.
    Lurch81#AC's Avatar
    Posts
    Global Posts
    1,135 Global Posts
    Carrier
    stock
    Default
    ok that clears it all up so as long as the wifi signal is up im on that network
  5. #5
    Posts
    Global Posts
    7,367 Global Posts
    Carrier
    Stock
    Default
    Yupp. As long as you have the little wifi indicator up there, you should be connected to that.
