Results 1 to 3 of 3
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,233 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default Setting ring tones?
    I downloaded a ring tone from crackberry and the only place I see it in music which doesn't give me the option to set it as a ring tone. When I go into phone ringtone its not there. I tried to do a search but didn't see anything.
  2. #2
    Default
    the way i've done it, is you go to your music library, find the song, then longpress on it and you will get the option to set it as a ringtone
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,233 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    That worked thanks!!
