Wifi issues - not able to see networks
irafcummings
8
I've been having a reoccurring issue with wifi connectivity on my Droid. I can connect to wifi at home, work, public networks, etc., without issue. Things will be great for a few months. Then suddenly (I don't change/install anything) the phone stops being able to find networks, even ones that it remembers. I try to forget the networks, add them manually, turn the radio on and off. Nothing has any effect.
The only thing that I've found fixes it is if I install/reinstall a ROM, and don't restore settings. If there was a solution that didn't result in me having to reinstall/reset everything, that would be awesome. Anybody have an idea?
FYI I'm using Peter Alphonse's GPA latest (not nightly) release, or Bugless Beast.
One of us is having the same issue. This is on a stock, non-rooted phone. The other, rooted phone seems to be doing fine.
r3dpuk3
