1. cward0625's Avatar
    I can't see a speed dial function on the Motorola Droid??? I couldnt find anything in the manual either. I see it has this on the motorola feature page:
    SPEED DIAL
    Direct dial shortcut, direct message shortcut
    I tried many things on the Phone feature, and I tried looking at the contacts edit options to see if you can assign them to a number. 1 works for voicemail so I figure i am just missing this somehow.
    11-08-2009 03:33 PM
  2. Snaz's Avatar
    In the meantime, you can add contacts to your home page until the trick is found.......
    11-08-2009 03:36 PM
  3. Adiliyo's Avatar
    the closest i've found is in:
    settings / applications settings / quick launch
    you can then assign a contact to a combination of the search button + a letter
    11-08-2009 04:31 PM
  4. austink's Avatar
    I created a folder on my homescreen and then place direct dial shortcuts in there for all of my speed dial contacts.
    I think that is what Motorola is referring to, since you can create a shortcut on the desktop to direct dial any contact number. I just moved it to a folder to save desk space (only adds one tap, and avoids need to open keyboard)
    11-08-2009 06:41 PM
  5. Mr.Miagi's Avatar
    how do you add contacts to your home page or direct dial contacts?
    EDIT: Nevermind, I was looking under widgets instead of shortcuts.
    11-09-2009 09:33 AM
  6. potroast#AC's Avatar
    I'm not a fan of the direct dial shortcut thing. Speed Dial Old School comes pretty close to the way I'd rather do it. Press a shortcut number then the phone button. Press and hold would be even better.
    03-26-2010 10:16 PM
  7. thebizz's Avatar
    The shortcuts are great for me save a lot of time when dialing some numbers
    03-26-2010 11:58 PM
  8. WAM's Avatar
    i always accidentally press those darn shortcuts and call someone in the middle of the night, not a big fan of them
    03-27-2010 12:11 AM
  9. thebizz's Avatar
    Just dont put it on the main home screen
    03-27-2010 12:17 AM
  10. WAM's Avatar
    lol tried that, didn't work. i'm clumsy :P
    03-27-2010 12:53 AM
  11. ncc1701p's Avatar
    Dialer One FTW
    speed dial 2 - 9
    03-27-2010 01:25 AM
  12. Nechasin's Avatar
    + 1 for dialer one app. It has made my dialing experience ago much better.
    03-27-2010 12:06 PM
  13. nylaw620's Avatar
    bug in software or not and it's no big deal. It involves speed dialing. I actually find it easier to dial someone who I call alot by adding a contact widget to one of my screens. Alternatively when in dialer if I hit settings then it brings me to the speed dial list. I should be able to just hit a number and when it brings me to a contact list just type in the name of the contact and tap the number for it to be assigned a speed dial number. What happens is this though. If I hit ba for example and it brings up bal which is a verizon contact preinstalled (#bal) it assigns it with no problem. But if , for example, I type in jef to get your name and then tap on one of your numbers it doesn't add it to speed dial. However, if I hit a speed dial number and then scroll down to your name and tap it and then tap one of hour numbers it will add it to speed dial. I went to vzw. They suggested a hard reset. They said if that doesn't work I should realize that the operating system is being constantly updated and not to worry. *As I said I am able to create speed dial contacts but not the way I should. Is this just an os problem or problem with my device. I did the hard reset but no difference.
    11-07-2010 09:21 AM
