Results 1 to 2 of 2
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Exclamation Droid FAQ's (Updated 6/30): Please Read Before Posting
    The following are frequently asked questions within the Droid forum. This page will be updated frequently, and suggestions are welcomed. Please PM me if you have a suggestion or would like to add additional content.
    2.2/Froyo Update
    1. It's Official: Droid Getting Froyo.
    2. Click here to follow MotoMobile on Twitter for the latest updates.
    Documentation:
    1. User Manual, Help Topics, & Interactive How-to Simulator.
    2. FAQ's, user guides tips/tricks, and software updates for the Motorola Droid on Motorola's product support page.
    3. Official Tips & Tricks PDF.
    How to:
    1. Copy and Paste.
    2. Automatically dial voicemail password.
    3. Configure Yahoo Mail (free version).
    4. Add Custom Notification Sounds & Ringtones.
    5. Hard Reset the Motorola Droid
    6. Charge your Droid via PC.
    Known/Common Issues:
    1. Facebook Notifications & Widget Not Updating.
    2. See this thread for: Picture messaging (MMS) Error: "you have entered an invalid address" (Error resolution now inside thread.)
    3. Authentication Failed message when trying to sync Corporate Calendar with Exchange server.
    4. Dust under the screen.
    Random:
    1. Wallpaper and Ringtones
    2. If I exchange/replace my Droid for a new one, will everything be transferred over?
    3. Syncing with iTunes solutions.
    4. Case options. This is the thread to discuss what case you are currently using to protect your Droid.
    If you do not see an answer to your question above, please use the SEARCH feature of the forums, to look for a solution, before starting a new thread.
    Last edited by Cory Streater; 07-30-2010 at 05:15 PM. Reason: Added info about 2.2 update.
    Thanked by:
    vaspo
  2. #2
    Default Motorola Droid Ultra FAQ
    - - - Physical - - -
    Will the Droid fit into either dock with a protective case?
    No, only the flat adhesive plastic-type protectors (InvisibleShield) are slim enough to allow the phone to fit.
    How easy is it to scratch the Droid?
    The glass on top of the screen is very durable and keys will have a very hard time scratching it (I've tried). There are a couple videos of people trying to scratch it as well and failing. The bits of shiny plastic on the back can get scratched, though. Look here
    - - - Hardware features - - -
    What's the resolution of the Droid?
    854x480
    What do the two dots/holes at the top of the Droid do?
    The one on the left is an IR emitter and sensor to blank the phone during a call when it's against your face. The one on the right is a light sensor to activate automatic brightness.
    Can I change the color of the notification LED?
    Yes, but only with third party apps like Missed Call and SMS Popup.
    How do I get into the two dock modes without the docks?
    For multimedia mode, download an app called DockRunner. For car mode, Android actually includes an application called Car Home. You can also hack it by putting a linearly polarized magnet, like a small cube magnet, on the back near the camera.
    Can I tether?
    Yes. Set it up through Verizon or look here.
    - - - Performance issues - - -
    What's wrong with my camera?
    As of yet, the camera software is sort of broken and takes a long time to focus and save. It will supposedly be fixed in an update on December 11.
    Why won't my home screen switch to landscape mode when rotated?
    Nobody knows yet, but so far everybody has this problem. This fix might be included with the next update.
    Why does switching homescreens or opening trays lag?
    Homescreen lag/jerk is present on all Droids at the moment, but I've found that the Locale service really drains your CPU and makes animations lag even more. Also try using a task manager to free up some memory.
    - - - Android OS and apps - - -
    Why won't my phone rotate?
    Check to make sure you have automatic rotation enabled in the sound and display settings.
    Why does my screen dim randomly?
    It's the automatic brightness feature. Turn it off in the sound and display settings under brightness.
    How can I see what's been using my battery?
    Go to settings, about phone, then battery use.
    How do I check for phone updates?
    Go to settings, about phone, then system updates.
    Why won't my apps close completely/how do I kill programs?
    Get a task manager from the app store such as TasKiller; the services manager in the Applications page in the settings isn't very useful.
    How do I uninstall apps?
    Press the menu button, go to settings, applications, manage applications, then select the program from the list and uninstall.
    How do I check for updates for my apps?
    Go to the Market, then press the menu button, then Downloads. If you have any programs that need updates they'll be at the top of the list.
    How do I copy and paste?
    To copy in a text box, long press it, then "select all" or "select text", then long press again and select copy. To copy a link or email, long press it and then select copy. To paste, long press a text box and select paste.
    How do I rename folders?
    Click the folder to open it, then long press the gray bar at the top of it.
    How do I open voice search?
    Long press on the search button on the phone.
    How do I remove widgets and icons?
    Long press it, then move to the app tray button which will then have a trash can icon on it.
    What size should my backgrounds be if I don't want to crop it on the phone?
    960x854
    Can I make my wallpaper crop square bigger?
    Press on a corner of the crop box and then drag it to size.
    What size should my contact photos be to prevent pixelation?
    I'd say around 250x250 or higher.
    How many apps can I download and store on the Droid?
    As many as will fit in the onboard 256MB as of now, but you can put any other type of file on the SD card.
    How do I turn off SMS notifications so I can use third-party apps like SMS Popup?
    Go into the Messaging app, click the menu button, settings, and at the bottom, uncheck "notifications".
    - - - Music and video - - -
    Why is the Droid's video recording quality so bad?
    Open the video camera application, open the menu, and set the video quality to high.
    Why doesn't the Droid have a video player/play my video files?
    The video player is in the gallery. You have to open the gallery and the folder with your video. Only videos encoded in MPEG-4/H.264 (.mp4) will play, and it shouldn't be larger than 854x480-ish or your phone might stutter or crash.
    How can I transcode video to play on the Droid?
    Some people have had luck with a program called Handbrake, but I use SUPER even though it's a bit complicated to use.
    How do I get songs, video, etc. onto the Droid?
    How do I get my computer to see the Droid's SD card?
    Plug in the USB cable, then bring down the notification tray. Click on the one about USB, then click mount.
    Why do Youtube videos look so bad?
    When the video starts playing, click menu, more, and "watch in high quality".
    - - - Verizon - - -
    How much does it cost for unlimited data?
    For unlimited phone data, it's $30 a month on top of voice and other features.
    - - - Tips, tricks, and cool stuff - - -
    Where can I get high-res backgrounds for the Droid?
    Look here or at DPReview for some nice pictures. Just make sure they're close to 960x854 or bigger.
    - - - Recommended apps - - -
    TasKiller - my personal favorite - lets you close unused apps and processes as well as ignore ones you always want running; comes with a couple widgets to quickly close applications
    Communication
    Google Voice - saves voicemail to your GMail account and transcribes them to text
    Meebo IM - all-in-one IM suite
    Twidroid - Twitter
    Missed Call - custom ring and vibrate settings as well as LED color and settings
    SMS Popup - replacement for Android SMS notifier (turn stock off to prevent doubles)
    Save MMS - allows you to save MMS attachments
    WiFi Buddy - detailed WiFi information and settings
    Music and sound
    Album Art Grabber - gets missing album art for your music
    Frequency-Generator - sine, square, saw, and triangle wave generator
    gStrings - customizable instrument tuner; also works for voice and other sounds
    Instant Lyrics - open while playing a song and will open its lyrics
    Scrobble Droid - enables Last.fm scrobbling in the Android music player
    Pandora - online radio
    Shazam - analyzes a part of a song that's playing through speakers and tells you the name and artist
    Images
    PaintNote - MS Paint-like app
    Photoshop Mobile - basic editor and online album
    PicSay - multitouch image viewer/editor
    Location
    Car Finder - press once when you park and saves your location on its map, and will show your location as well so you can find your parking spot
    Find My Droid - lets you turn up the volume and activate ring and GPS to locate your phone; uses an SMS code phrase
    Google Places Directory - lists categories of places in your location; searchable
    GPS Status - 360 degree compass, horizontal and vertical level, g-force sensor, magnetic field sensor, GPS location in long/lat, shows speed and elevation
    Reference
    aCar - stores your car information
    Barcode Scanner - scans various types of bar codes and Google searches them
    ColorNote - text, drawing, and voice note program
    ColorDict - comprehensive dictionary with multiple add-ons available
    PDFGView - PDF viewer
    ShopSavvy - barcode scanner with built-in product lookup
    Speed Test - Ookla's speedtest.net application
    Unit Converter
    Money
    Bank of America - online banking and account management
    FX Currency - comprehensive currency converter
    Google Finance - stocks
    PayPal
    Security and other
    Battery Status - widget that shows battery level and lots of other system metrics when clicked
    DockRunner - enables multimedia dock mode without needing the dock
    Find My Droid - see above
    G-backup (trial and pay) - backs up almost anything you want to Google's servers
    MyIP - shows your phone's IP
    Text-To-Speech Toy - converts input text to speech
    Games
    Labyrinth
