Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    bart151's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Applications re-opening, help!
    Hey everybody,
    So far Im loving my new Droid, what an awesome trade from my Storm 2 even though I enjoyed the Storm 2, after playing around with the Droid I had to switch
    Now, onto whats going on with my phone. I, like many other people have Task Killer on my phone to kill the tasks running on my phone. However, whats going on is when I hit the shortcut on my phone to kill all the apps, immediately within 10 seconds I have anywhere from 2-8 apps running again. They dont pop up on my screen but their running in the background.
    The apps that keep opening are:
    Settings
    Corporate Calender(no idea what this thing even does to be honest, I may uninstall it)
    Calender
    My uploads
    These seem to be the norm that are opening up in the background and I have no idea why. Is this usual?
    Any helps appreciated!
  2. #2
    tdawgui's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by bart151 View Post
    Hey everybody,
    Settings
    Calender
    My uploads
    Settings is standard for your phone... runs in the background to keep track of your settings for your phone. You can't do anything about it.
    Corporate Calendar is the calendar that connects to your outlook calendar if you chose to sync it with an exchange server.
    Calendar is just a calendar... its set to automatically run in the background.
    My uploads -- ? must be an app you downloaded... If you don't want it always running try looking in the settings for that app or uninstall it.
    Messages - (do you mean Messaging?) - Messaging is your text messages... runs in the background so it can alert you when you get a new text message... don't worry about it.
  3. #3
    largeselection's Avatar
    Posts
    Global Posts
    823 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have other weirder apps that open...these have all been open randomly...
    Camera
    alarm clock
    corp calendar
    Car home (wasn't in dock)
    Youmail
    notepad
    Google voice
    So do these need to keep opening? Why car home, I prefer to open youmail when I need it since I get emails of my vms mostly.
  4. #4
    Roy Aguilera
    Roy Aguilera's Avatar
    Guest
    Default
    Quote Originally Posted by largeselection View Post
    Camera
    alarm clock
    corp calendar
    Youmail
    notepad
    Google voice
    Do you have a navication dock? If so it opens up when you set it on the dock.
  5. #5
    04redgto's Avatar
    Posts
    Global Posts
    941 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    This isn't as big of a deal as it it on WinMo, or Blackberry's. The droid will close low priority programs as needed for memory purposes. I wouldn't even worry about it at all! I have run Advanced task killer, and it has said closing 22 programs before, and even then the phone never ran slow/laggy!
  6. #6
    Roy Aguilera
    Guest
    Default
    Exactly. Best of all no bat pull is needed.
  7. #7
    mskaplan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'd also like to have some of these killed to keep memory free. I don't use corporate calendar at all, but it refuses to go away. Why would I want something running in the background that I will never use. I can't even seem to uninstall it. Same with bluetooth. I never use bluetooth and never will, but the app is running in the background taking up memory. Is there a way to get rid of these (if I kill with ATK they pop up 10 secs later like the OP said) or is the consensus that they truly will not impact performance of the phone?
  8. #8
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    6,852 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Amazon.com: Linux For Dummies, 6th Edition (9780764579370): Dee-Ann LeBlanc
    Sorry couldn't resist
    Go to the market. Download a terminal client. Issue the command
    top
    See how little those apps actually use in terms of resources while they aren't running. Note that it is much less than it would be if every app had to code all functions in itself like a BB. The phone runs BETTER with them in the background than it would without. There is nothing to be alarmed about here.
  9. #9
    mskaplan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    LOL! Thanks for clarifying. I guess I am just paranoid coming from a Blackberry. Man things in the background would KILL my blackberry. Right now I am getting paranoid since I have weather, twitter, USA today running in the background along with all of this stuff that I DONT need, like Corporate Calendar, Bluetooth, etc. Is there a way to uninstall? I mean I never plan to use Bluetooth and I don't have exchange so Corp Calendar is useless..... But you seem confident in assuring me that my performance will not suffer as a result, no?
  10. #10
    AC Cowboy
    Posts
    Global Posts
    6,852 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    You're fine. Until the droid gets rooted you're stuck with VZW's ideal setup, which may differ from yours. It's probably a very usable setup for most everyone though.
    Honestly, stop using a task killer and give it 2 or 3 days without rebooting. It will settle in very nicely. The OS will "learn" what types of services you use.
    For example if you need location services alot, maps will have to open. As older unused things get closed, maps moves closer to the top of the list to stay open, and replaces whatever was there running before. Then when you need location services, they are already running and just need to display the data. This is an example, so maps is a made up service. Don't look for it
  11. #11
    Roy Aguilera
    Guest
    Default
    I think it has a ton to do with how bad it was for apps to run on the BB's and how much lag it would cause. Bringing up the white screen of death. This is just the ex BB users way of detoxing. They keep using ATK every hour or so. Stop worrying and enjoy the freedom.
  12. #12
    Posts
    Global Posts
    823 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hahhaa yup, I kill tasks like I'd kill zombies, in vast quantities and as often as possible.
  13. #13
    jjenson's Avatar
    Posts
    Global Posts
    278 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I am slowly learning to not use task killer but I still do it once a day lol.
  14. #14
    SharonW's Avatar
    Posts
    Global Posts
    640 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by gbhil View Post
    Oh man, the phone learns from you and starts to subordinate lesser-used apps? That is seriously cool!
  15. #15
    jdella681's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ah thank god! I thought there was something wrong with my phone. Coming from a blackberry storm I have the habit of viewing my memory usage to make sure its running optimal. Actually even with like 20 apps in the background running there's no lag! I gotta kick this habit..
  16. #16
    AC Cowboy
    Posts
    Global Posts
    6,852 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by DA6 View Post
    Perfect analogy. BB users need to realize Android is more like their computer OS than it is like the Blackberries. All the apps can share and use each others code if needed, rather than pull from a set of master functions.
    Quote Originally Posted by SharonW View Post
    Learn is a bit of a stretch, but still a great way to describe it. Apps with functions you rarely use will get closed and rarely get reopened. Apps you use often will be elevated in status enough that they don't make it on the "lets close this 'cuz we ain't using it" list very often, and remain available for you to use. Sprint Nav is a great example on the Hero. Everything from Peep to Fb to the Browser use it for location service. It's much faster to let it stay alive in the background than it is to load it each time you need a function from it.
    Android is the future for mobile devices.
  17. #17
    kunak83's Avatar
    Posts
    Global Posts
    16 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Forgetting about the memory use of an app running in the background, What is the effect on the battery as far as leaving them run?
  18. #18
    YoungChrisG's Avatar
    Posts
    Global Posts
    404 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.2.2 GS4
    Default
    Quote Originally Posted by kunak83 View Post
    That would be app dependant and what tools it utilizes in running i.e. blue tooth, gps, wifi etc.
  19. #19
    hatch.duffy's Avatar
    Posts
    Global Posts
    173 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I check my task killer about every 10 minutes as well. Well at least I did when I first got the phone last week. I too am coming from a BB storm, and 3 other blackberries before that so it's probably just a habit to keep checking memory. A few days ago I stopped worrying about it and have not seen a difference at all in the performance of my phone.
    Gotta kick those old BlackBerry habits!
  20. #20
    darkstar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    my battery life was really suffering in the very beginning... the biggest improvement came from turning on the auto screen brightness option and taking gbhil's advice.. stopped killing processes... phone is running just fine..
  21. #21
    jjenson's Avatar
    Posts
    Global Posts
    278 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yeah I had the screen on full brightness and that ate through my batter. Now I auto adjust and honestly its really good. I love that feature now.
  22. #22
    Posts
    Global Posts
    823 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Today was my first full day with NO task killer installed. For the majority of time (85-90%) I did not notice any slow down. However, there was some at times. At one point when I looked in the "running applications" section I saw I had just 7.2 mb free + 40MB in 9. Currently I show 12MB+53MB in 10 Other 47MB in 3... Still don't know how to interpret that... can anyone explain?
    Also, will this get better as the droid "learns"? I don't want her to get down to 7.2mb on a regular basis.
  23. #23
    AC Cowboy
    Posts
    Global Posts
    6,852 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    If it's just a random occurrence, it will sort itself out eventually. If it's "leftovers" from apps you run then close from time to time, it may not. I would use the task killer to selectively kill things you pull open, then will not need until you open them yourself again.
    To get a better idea of your free memory, download a terminal emulator and run
    df -h
    in landscape. It will tell you free/used info on all the mount points on your phone
  24. #24
    JRoid's Avatar
    Posts
    Global Posts
    45 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i stopped using tk's and seems to be running pretty smoothly. We ex-bb users need to stop being ocd about our internal memory. good luck everyone.
  25. #25
    au_dog's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cool Applications Running unexpectedly
    Curious, why this is considered benign. I observed that the web-browser would keep pinging updates of the page it is on (say financial.google.com). Someone who bought the phone without the data-plan (there is a wifi, so you don't ) would essentially be getting dinged, it seems.
    Also, just because viruses are not yet common, this seems to be laying the foundation for virus hell. The uncontrolled launching of apps, the inability to remove unused/unneeded/unwanted apps leaving legacy hooks to for the creative.
    This one feature, the inability to "take control" of what I want running, just hasn't settled in / it is wrong and does have subtle consequences, even if "top" says its not making it slower.
    Not yet sold that one should accept this so lightly. Perhaps I too will be assimilated, "http://memory-alpha.org/en/wiki/Assimilation". But alas, a lone individual, with nothing to offer - likely to be ignored.
