Results 1 to 5 of 5
    Default Droid signal drops when using phone
    When my Droid is just sitting idle it has full signal four bars. Also keeps four bars when on the internet. But as soon as I dial a number and press connect the signal drops to one to two bars. When I hang up it immediately jumps back up to four bar. Anyone else experience this or know why this happens. Thanks
  2. #2
    Default
    I think when you are on a call, it switches off of 3G, so you have 4 bars of 3G service, but in call you see the voice signal, which is seperate. I could be wrong though, but the 3G icon does disappear, which makes me thing i might be on the right path.
  3. #3
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    2,067 Global Posts
    Default
    Do your calls drop? If not I would not worry about it.
    I forgot the obvious "You are holding it wrong"
  4. #4
    Menno's Avatar
    Coffee Addict
    Posts
    Global Posts
    710 Global Posts
    Carrier
    CM9/Franco Kernal
    Default
    Verizon phones use two totally separate technologies for their 3g and their voice data. Voice is transmitted on 1xrtt (this can also be used for data, but it's painful like edge). High speed data (3g) uses EVDO. A verizon Cell cite has different antenna's for 1x and EVDO.
    Smartphones like the droid will show your 3g coverage if you have it since if you have 3g, you ALWAYS have 1x of some kind. It will show you 1x once you start using that radio instead, or if there isn't a strong 3g signal.
    But, "bars" mean less on CDMA phones than they do on others. unless your phone actually says "searching for service" you'll be able to make a call, even if no bars are showing.
  5. #5
    jcg878's Avatar
    Posts
    Global Posts
    25 Global Posts
    Default
    Sorry Steve Jobs, maybe you're not holding it correctly.
