1. xocarrie's Avatar
    I have had my Droid for about 7 months and today my power button suddenly lost its click, as if it's sunken in. It takes 2 or 3 presses to turn the screen on. I googled the issue and this seems to happen to many Droid users. I read that Verizon will replace the phone with a refurbished one for this issue... but if I do that will that be my "one replacement" under warranty? If so, I'll just wait until right before mine runs out in Dec. It is annoying though :/
    08-05-2010 05:13 PM
  2. brandonx1000's Avatar
    one replacement?
    if you have a phone with issues, you can get it replaced as needed within that one year
    08-05-2010 06:50 PM
  3. xocarrie's Avatar
    Should I call or bring it to the store?
    I am just worried a refurbished one will have more issues...
    08-05-2010 09:54 PM
  4. corydunbar's Avatar
    refurbished phones are supposed to be fully functional but bay have some visual scratches.
    08-05-2010 10:53 PM
  5. nickf126's Avatar
    My power key is the same. It does not "click" anymore. Anoying. So you are saying that if I bring it in they will give me a new one?
    08-06-2010 01:40 PM
  6. Dirrk's Avatar
    Yes that is correct, you have a 1 year warrenty with your device, you can use an unlimited amount of times and it is free. The insurance is the one with limitations, you can only use it twice in one year.
    08-06-2010 03:46 PM
  7. Dirrk's Avatar
    Or call 18664065154
    08-06-2010 03:47 PM
  8. xocarrie's Avatar
    Will they be able to transfer all my applications and such?
    08-07-2010 12:03 AM
  9. brandonx1000's Avatar
    no, when you enter your gmail account, you contacts will come back...apps you will need to redownload
    08-07-2010 09:15 AM
  10. nickf126's Avatar
    Wow, Thanks guys! That's great!
    08-07-2010 10:36 AM
  11. jammin's Avatar
    This just suddenly happened to me. Are they replacing anyone's droid1 with droid 2s?
    10-01-2010 11:22 PM
  12. jammin's Avatar
    I guess not, I'm getting a refurb droid 1 =( lol i just tried
    10-02-2010 11:09 AM
