Results 1 to 11 of 11
    Default led light suddenly blue?!?
    ok i was opening a message and the blinking green light suddenly turned solid blue, y would this happen? nothing i did would turn it off, i finally turned off my phone and turned it back on. it is now gone, y would this happen?
  2. #2
    D-LuX's Avatar
    Posts
    Global Posts
    74 Global Posts
    Default
    does this when hi yahoo gets a message on my phone. Some apps you can set a notification, and their color
  3. #3
    Default
    I get a blue led when I get a twitdroid notification. I turn it off by clearing the notifications.
    Default
    but there was nothing in my notifications, i just had opened a message...
  5. #5
    Default
    I have blue = twitdroid
    Green = Gmail
    Orange = Missed call
    Default
    where would i go to see the different colors of led's that i can see, and is there a way to change the color?
  7. #7
    Scott4551's Avatar
    Posts
    Global Posts
    67 Global Posts
    Default
    Twitdroid for me too is blue...
    Iphone 3g > Storm 1 > Imagino > Storm 1 > Droid> Storm 2 > EVO 4G
  8. #8
    s-one's Avatar
    Posts
    Global Posts
    40 Global Posts
    Default
    Facebook app also does blue notifications when you get an inbox msg in facebook. You can also see the different LED colors if you use the Missed Call app in the market. The app lets you assign different LED colors to some of the different services such as calendars and sms.
  9. #9
    Default
    Quote Originally Posted by trentandrews View Post
    Green = Gmail
    How do you set Orange for missed calls?
  10. #10
    Jeremy's Avatar
    Original Member
    Posts
    Global Posts
    10,096 Global Posts
    Default
    Quote Originally Posted by cheeta186 View Post
    That totally depends on the application and if it allows that.
  11. #11
    Default There is a malfunction with the software, i called verizon. I had the same sitation.
    I had the same situation, there is a malfunction in the programming and or software. I called verizon, they confirmed this.
