Results 1 to 13 of 13
    miamiboy305's Avatar
    Posts
    Global Posts
    20 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Droid Audio through Laptop Speakers?
    Ok I just started a road trip from miami to north carolina and I have my droid and my laptop however I don't have internet on the laptop. My question is is there a way that I can open pandora on the droid then use the micro usb or something to play the music through the speakers of the laptop because the laptop has good harman/kardon speakers.
  2. #2
    Jeremy's Avatar
    Original Member
    Posts
    Global Posts
    10,099 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Nothing that I am aware of. Don't think it's possible.
    Posts
    Global Posts
    20 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Its going to be a long 15 hours......
  4. #4
    Roy Aguilera
    Roy Aguilera's Avatar
    Guest
    Default
    I am able to use a auxiliary cable and play Pandora through my cars speakers.
  5. #5
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by miamiboy305 View Post
    I doubt you'll find anything to do what you're asking, but how are the speakers in the car? If your car stereo has an input jack you could plug your phone into that. I do that all the time.
  6. #6
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Title edited & off topic posts have been removed.
  7. #7
    ostrich's Avatar
    Posts
    Global Posts
    7 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Does your laptop have a microphone jack? You may be able to use that as an input.
  8. #8
    bmderuosi's Avatar
    Posts
    Global Posts
    225 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    If you have bluetooth on your labtop the droid can do stero bluetooth, as in it plays all audio to the connected device. If not, try the other suggestions.
  9. #9
    Tzen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Install PDANet. Connect the laptop to the DROID to get online. Go to the Pandora site on the laptop. Play the music from the laptop.
  10. #10
    chrislitzkow's Avatar
    Posts
    Global Posts
    144 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Male/male aux cable. Simply done... plug one end into your phone and the other into the mic jack on your laptop. Works perfectly on my Toshiba table PC, can't say that it will work with every brand but seems reasonable that it would be the same. Good luck!
  11. #11
    Adiliyo's Avatar
    Posts
    Global Posts
    3,278 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Christopher View Post
    that would be the way to do it aside from tethering
  12. #12
    ddarvish#IM's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    bluetooth will allow you to have all the audio from ur driod come out ur computer speakers
  13. #13
    Oliver84's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Are you guys kidding me? I'm playing audio through my laptop speakers from my Droid right now. I'm not sure if this is a new thing with the update but if you just plug in your Droid (don't mount it, just plug it in) and start up Pandora, a movie, or whatever the audio will come straight out of your computer speakers. Can anyone say, car dock? There's gotta be a way to integrate this with your car. If there is, then the iPhone's connector has just gotten way gay. The only reason I put up with it is because you can charge and send audio through it. But now I see that you can do that with the Droid's connector too, and guess what? It's a UNIVERSAL connection! Take that, iPhone! =)
