Results 1 to 5 of 5
    Default Need a little help
    Just wondering if anyone can gimme a hand here. I work at a store and a customer is having an issue with his Droid after update to 2.2. It seems his bluetooth headset will no longer auto-connect to the phone, it will auto pair, but not connect. He needs to go into his settings and then to the bluetooth menu to enable it every single time. He said it used to auto pair AND connect instantly on 2.1. Anyone else have this issue, or know a way to rectify it? Thanks.
  2. #2
    Default
    Yup, I've had some issue but a reboot seems to fix it for a while.
    Overall, 2.2 has been a negative experience for me.
    Thanked by:
  3. #3
    Default
    No issues thus far with my Jabra. I use Dazzle toggle widget to turn bluetooth on and off.
    Moto Droid 1 w/Froyo
    Default
    Thanks for the quick reply, I was hoping there was going to be a better option than that, but kinda figured that was going to be the response. I guess I'll tell him the bad news...
  5. #5
    MrSmith317's Avatar
    Mr Fix-It
    Posts
    ROM
    Stock Rooted
    Default
    I had an issue like this. I re-paired the headset to the phone and everything was aces.
    *Using a plantronics voyager pro*
