1. Jeremy's Avatar
    Could come in handy for some of you.
    1. Turn the Droid off. If it wont turn off, take the battery out then place it back in.
    2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appears.
    3. Press the Camera and Volume Up buttons at the same time to get to the menu.
    4. Use the direction pad to the right of the keyboard to select the Format option.
    NellieRae likes this.
    11-28-2009 11:46 AM
  2. mclarryjr's Avatar
    Thanks that is good to know.
    11-28-2009 11:49 AM
  3. equus's Avatar
    Sticky please or move it to Tips & Tricks. Does the "search feature " find this topic if a newbee or anyone "searches this"?
    Correction>>>> YES the Search button will find this topic IF you type "hard reset"........
    11-28-2009 12:34 PM
  4. Jeremy's Avatar
    You were close...
    http://forum.androidcentral.com/moto...e-posting.html
    Or you can type "reset" and the thread also pops up.
    11-28-2009 12:55 PM
  5. ChocoBilly's Avatar
    Could you please explain the different formatting options that appear? Thanks!
    12-03-2009 10:06 AM
  6. mweaver_ciss's Avatar
    I was wondering... when I hard reset is done what happens to the phone account information already existing on the phone such as the phone's number and carrier information?
    02-25-2011 10:40 AM
