Results 1 to 3 of 3
    guitarevan07's Avatar
    Posts
    Global Posts
    150 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default What case/protection is everone using for their Droid?
    I tried out the body glove and I just hated it. Bulky and makes the slide out keyboard pointless because i can't hit the top row of buttons easily because of my big fingers. Also had a hard time sliding it out.
    Thinking of getting the ZAGG invisible shield.
    What's you all's favorites?
    BTW, for recommendations, im not interested in clip cases nor pocket pouches.
    Thanks!
  2. #2
    pwrmetal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have the same (or similar) case/glove as you and I have the same reasons for not liking it. I have just been taking it off when I am indoors (luckily the 2 pieces snap on/off pretty easily). I'll probably replace it later if I hear about something that works better. It's too bad as I love the feel of the case but it really does make sliding/using the keyboard difficult....
  3. #3
    Jeremy's Avatar
    Original Member
    Posts
    Global Posts
    10,099 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
