1. Noseeums's Avatar
    Hey folks,
    I remember, from phones in the past, that their useful battery life would somehow be significantly reduced if I used them while they were charging.
    Does the Droid's Li-ion battery share this same wear & tear trait? The only reason I ask is because I've had three Droids. The first two had great battery life, but this third one drains rather quickly. The only thing I've done differently with this third Droid is I have used it a lot while it was charging. Using it while charging seems to create extra heat (which I think may be the culprit to reducing usable battery life).
    Just curious. I've never read any official stuff on this subject, but I've experienced it in the past.
    12-19-2009 01:44 PM
  2. droidweasel's Avatar
    Nay I use mine while charging daily. Since day one and I have awesome battery life. Fyi
    12-19-2009 02:09 PM
  3. TootNBerry's Avatar
    I use mine also alot while charging and the battery seems fine..
    12-19-2009 02:34 PM
  4. mclarryjr's Avatar
    I don't think using your Droid would have any bad effect on your battery. I use mine all the time when charging and haven't seen any difference since day 1. If the battery is real bad I would call Verizon or go to one of their stores and see if they won't replace it.
    12-19-2009 04:03 PM
  5. Chris Kerrigan's Avatar
    I haven't experienced any issues in battery performance because I use it while it's charging. The only thing is it might take it longer to charge because you're using it, but other than that I can't see how it would hurt.
    12-19-2009 04:05 PM
  6. eventnick's Avatar
    This has confused me so does this phone have a LiPo (Lithium Polymer) or a Lithium Ion (Li-Ion) battery? They are very different chemistries and that battery label identifies it as "Lithium Ion Polymer"
    12-19-2009 05:48 PM
  7. raequinn's Avatar
    Most important thing is to initially fully charge and fully discharge a couple of time. That helps set the battery memory. Then your good to go with charger on or off.
    12-19-2009 05:49 PM
  8. Chris Kerrigan's Avatar
    The battery is a lithium-ion polymer battery.
    12-19-2009 06:06 PM
  9. ericatomars06's Avatar
    I charge mine and talk on it all the time.. Sometimes it shocks me... thats not cool, but I use the Pandora App all the time while I'm charging it and the battery still charges. I haven't seen any problems with it, and if i forget to charge it at night its fine in the morning...
    Has anyone gotten an extra battery for swap it our on their phone or has anyone had to change their battery?
    12-19-2009 10:15 PM
  10. Thormas's Avatar
    My battery runs out even when charging what to do?
    08-26-2013 07:14 AM
  11. blackjaguar25's Avatar
    Upgrade your thousand year old phone.
    08-29-2013 09:55 PM
