Results 1 to 3 of 3
- 12-30-2009, 02:20 PM
Thread Author #1
Shortcut Help
I have handcent installed. I enabled quicktext and set it so that when I long press the search button it opens quicktext. I decided I don't like the quicktext feature so I turned it off. However when I long press search it still tries to open quicktext. How can I change it back to when you long press search it opens voice search? Any help is greatly appreciated. Thanks.
- 12-30-2009, 02:27 PM #2
Go to settings>applications>manage applications then scroll down to the Launch by Default section and click the Clear Defaults button.
- 12-30-2009, 06:54 PM
Thread Author #3
thanks so much
Reply
