Results 1 to 8 of 8
    Cirro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Anyone run into this contacts problem?
    got a phone call from a friend and added him as a new contact. However he wasnt in my contacts. Ive readded him 4 times and still he drops out of my contacts everytime. Anyone what the deal is? droid
  2. #2
    YoungChrisG's Avatar
    Posts
    Global Posts
    404 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.2.2 GS4
    Default
    Quote Originally Posted by Cirro View Post
    Is his name similar to anyone elses in your contacs? i.e. Jeff, Jeffrey, Jeffrie or Jessie, Jessica, Jess? If so check the other contacts for the name and there should be an option to seperate them.
    Cirro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    nothing even close to his name im getting very aggitated
  4. #4
    Posts
    Global Posts
    404 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.2.2 GS4
    Default
    Do you have more than one Gmail account associated with your Droid?
  5. #5
    vsugorilla9's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i dont know if this is a true work around or not but i ran into the same problem and what i had to do to get it to finally save the number was i had to save the number as a home number instead of mobile and then after it saved i edited it to a mobile number. i dont know if this is a bug or what but that is what i had to do to add a new number.
    Cirro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    no other gmail accounts either vsugorilla am trying this now
    Cirro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    seems to have worked thanks :-)
  8. #8
    Zorro1's Avatar
    Posts
    Global Posts
    1,056 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    There are bugs in this overall lousy contact list. Sometimes, it won't alphabetize by last names, but picks the first instead. Some it won't let you add to faves until you delete it and re-enter. Weird stuff.
