1. trackizmy1's Avatar
    What should I do since my droid isnt turning on. The battery died yesterday then 2 hrs later I went home and plugged it into the charger. Then 30 min later it wasnt turning on. I know I could just get a replacement but I have texts that came in while it was off.
    01-17-2010 09:00 AM
  2. nerdbox08's Avatar
    If you got messages while the phone was off they are still sitting on the server waiting to be delivered, which means if you replace before the original device can be turned on they should be sent to the new device.
    I'm not sure if you tried pulling the battery and putting it back in to make sure it's properly seated but if you have and that hasn't helped I would take it in to the store.
    Out of curiosity did a white light come on that is seated in the charge port? If not it might not have actually been charginging. Just a thought.
    01-17-2010 09:06 AM
  3. trackizmy1's Avatar
    O okay do you think they would make me pay the 50 dollars to replace it.
    01-17-2010 09:08 AM
  4. trackizmy1's Avatar
    And also what do I do about getting my apps back
    01-17-2010 09:11 AM
  5. nerdbox08's Avatar
    I edited my previous post twice. lol
    01-17-2010 09:13 AM
  6. droidbroke1's Avatar
    i dont know if your in the same boat as me but..last niite i was watching the football game..my phone was 75% charged...then all the sudden it turned off and now it wont power on..i plug it into the charger and the little light comes on the side..not the red notification light just the white one by the charger port...i bought this phone second hand from someone that worked at verizon..im pretty sure there not going to replace it, unless i can convince them that i bought it from them
    01-17-2010 09:14 AM
  7. nerdbox08's Avatar
    If the phone is defective they will probably replace it with a refurb at no charge. If you broke it and have insurance I believe the price is 89(read that in another forum don't quote me). as for apps I am unsure.
    01-17-2010 09:16 AM
  8. trackizmy1's Avatar
    Thats basically the same story just that mine wasnt 75% charged it was dead.
    01-17-2010 09:16 AM
  9. nerdbox08's Avatar
    If the phone falls under the one year manufacturers warranty even if you are a second owner they ' might' replace it.
    Verizon has done that for me in the past.
    01-17-2010 09:18 AM
  10. nerdbox08's Avatar
    01-17-2010 09:20 AM
  11. droidbroke1's Avatar
    well it hasnt been out for a year, the boy i bought it from was actually a veirzon employee.my sister bought a smartphone from somene second hand and they replaced it...im thinking it is something with a connection inside, the phone is in 100
    % perfect condition ahs never been dropped. never beenwet
    01-17-2010 09:21 AM
  12. trackizmy1's Avatar
    Or do you think the batter is damaged
    01-17-2010 09:23 AM
  13. nerdbox08's Avatar
    Then it won't hurt to try. I think they track the phones by ESN so if nothing comes up flagged you should be okay.
    01-17-2010 09:24 AM
  14. droidbroke1's Avatar
    what would cause it to get flagged...and no i dont think its the battery because when i plug it into the wall a white light comes on near the charger...
    01-17-2010 09:26 AM
  15. nerdbox08's Avatar
    If the charge light comes on and you can't hold a charge it very well could be the battery. I haven't heard of major battery problems but that doesn't mean it can't happen with a few of the devices.
    01-17-2010 09:28 AM
  16. nerdbox08's Avatar
    Who knows, but maybe someone attempted to pass possible water damage off as a normal defect. Not saying that's the case but I know people have tried it before.
    I might be mistaken but I think rooting the phone might void the warranty? Someone help me with that one.
    01-17-2010 09:32 AM
  17. droidbroke1's Avatar
    what is the manufacture warranty look like..i mean could i send it to motorola and maybe they fix it? im not really sure what to do i dont wanna drive to verizon if i dont have to but thats what its looking like im not really sure what could have caused it ive never had any problem with it before, besides it powering off and back on by itself...what does rooting the phone mean?
    01-17-2010 09:33 AM
  18. nerdbox08's Avatar
    Rooting the phone is essentially hacking it to gain complete access to the OS.
    As for the warranty I think you have to do it through verizon.
    01-17-2010 09:36 AM
  19. Adrynalyne's Avatar
    Insurance deductible is 50.
    01-17-2010 09:56 AM
  20. mjones73's Avatar
    It's $89 and you need to go through the insurance company directly if it's lost/stolen or accidentally broken...
    As for it just dying on it's own, take it up to the Verizon store and let them replace it.
    01-17-2010 10:03 AM
  21. trackizmy1's Avatar
    It was free but my verizon didnt have any replacements in store so I have to wait till wednesday
    01-17-2010 12:20 PM
  22. trackizmy1's Avatar
    Now I have to use my sisters old busted Dare until Wednesday .
    01-17-2010 12:29 PM
  23. nerdbox08's Avatar
    At least you're getting it replaced
    01-17-2010 04:20 PM
  24. tbracker's Avatar
    Mine died last night too.
    It was 70-80% charged when I went to bed at about 0200, at 1015 I tried to turn it on and it wouldn't work. Tried charging and nothing; no light. Took the battery out and put it back in and then it started working.
    I cannot have this happen again! I need to be in contact and have the alarm working.
    Anyone know what might have happened?
    01-18-2010 02:44 PM
  25. PJnc284's Avatar
    yeah, I just had a similar thing happen to me. Went to unlock it and nothing. Took the battery back out and put it back in. Nothing. Took the battery out again and it finally turned on when I pressed the power button. Had 80% battery. Thought I was going to be making a trip to verizon.
    01-18-2010 02:47 PM
