Results 1 to 25 of 25
    ikith's Avatar
    Banned
    Posts
    Global Posts
    435 Global Posts
    Default Battery pulls do not help your droid
    The droid is not a blackberry quit pulling the battery out of the phone. If you need to restart the phone turn it off then back on this does the same thing as a battery pull but without any negative side effects from pulling the battery!
    You are doing more hurt then help when you pull the battery so stop it stop it stop it stop it stop it stop it stop it stop it stop it stop it stop it stop it stop it!
  2. #2
    Default
    Ive had twice where it was necessary. The power on/off button doesn't always work if its locked up.
    Agreed most of the time though it is completely unnecessary to pull it out.
  3. #3
    Default
    agreed. i try to avoid telling my customers that.
    there are times when its nessecary though.
  4. #4
    Chris Kerrigan's Avatar
    Posts
    Global Posts
    4,016 Global Posts
    ROM
    Stock
    Default
    +1. I've only had to do a battery pull once, and that was when the power button would not power down the device after it locked up.
    New York Giants | New Jersey Devils | Colorado Avalanche | New York Knicks
  5. #5
    Default
    My Droid has locked up and wouldn't respond to anything battery pull very necessary at that moment..
    Follow Ya Boy @BiGTo0T
  6. #6
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    Quote Originally Posted by ikithme View Post
    I have 2 batteries, and go back and forth between the 2 throughout the day. Before I swap them out, I power down via the power button. I do this because it *feels* like a cleaner way of shutting down the system.
    Having said that, I'd like to hear your reasons for encouraging a power down. I'm unable to find a single warning in the user documentation about battery pulls, nor have I read anyone post that their phone failed to restart after a battery pull.
  7. #7
    Default
    Thank for offering any advice to help my droid run better and not do any harm. But, I'm always interested in "WHY". I agree it's definitely NOT a Blackberry, and I have to work hard to get that blackberry mentality out of my head.
    But, I rarely do / do not do something without knowing the reasons for it. I trust that you have our best interests in mind and offer the advice to help... and I appreciate that a lot. I'm just interested in why battery pulls are no good for the device.
  8. #8
    Default
    According to the manual, if all else fails, battery pull.
  9. #9
    j7469's Avatar
    Posts
    Global Posts
    732 Global Posts
    Default
    Quote Originally Posted by CSI Guy View Post
    Good to know that the manual references this. This way if a battery pull does damage the phone, at least we can say the manual said it was OK.
  10. #10
    Default
    There are times when a battery pull is necessary and doing so will NOT harm the device. A battery pull is a HARD reset and when your device just doesn't quite act right then I suggest doing so. Powering down the device is NOT the same thing.....
  11. #11
    DeeMat's Avatar
    Posts
    Global Posts
    282 Global Posts
    Default
    The only time I pulled the battery was to see what was behind it... On my Storm1 that was a different story.
  12. #12
    willymakit's Avatar
    Posts
    Global Posts
    934 Global Posts
    ROM
    stock
    Default
    Quote Originally Posted by DeeMat View Post
    For sure....
  13. #13
    Newps's Avatar
    Posts
    Global Posts
    6 Global Posts
    Default
    A battery pull is not a hard reset, it's a soft reset, the same as cycling with the power button. A hard reset brings the phone back to the same condition as when you first pulled it out of the box.
  14. #14
    Dapke36's Avatar
    Posts
    Global Posts
    618 Global Posts
    Default
    Preaching to the choir here.
  15. #15
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,807 Global Posts
    ROM
    Homebrewed
    Default
    Powering down via the button allows the ramdisk (a "fake" file system written to memory when system boots) to flush in the correct order, and writes any permanent data to the system. Pulling the battery just quits everything.
    Unless you've been fiddling in the /dev or /sys or /proc directory there's very little chance you can harm anything by pulling the battery, but it's not necessary.
    If your phone locks up, and you're rooted/monkeying around with it, here's my best suggestion:
    Plug it in to your PC
    type the following from the command prompt while in the SDK tools folder:
    Code:
    adb shell
    logcat -d > /sdcard/frozen.txt
    reboot
    This reboots (if possible) and saves an error log on your sd card as frozen.txt . This is v-e-r-y helpful when testing something, or generally doing things the phone wasn't designed to do
  16. #16
    Default
    Isn't the battery pull pretty much the last resort anyway? Who wants to pull it if it isn't necessary. I've had two lockups that didn't respond to the on/off button so out goes the battery. And since I've got a tight fitting glove case on my Droid, it ain't a lot of fun taking that off first.
  17. #17
    Default
    Quote Originally Posted by Newps View Post
    Not necessarily -- depends on the device. For example, hard resets (i.e. battery pull) on BB's do not affect data as a wipe was distinct and different from a reset. I wouldn't refer to a battery pull on a Droid as a soft reset either. There are some cases where a battery pull and cycling power with the power button do not have the same results.
  18. #18
    Default
    Straight out of the Owners Manual. Troubleshooting
    we’re here to help
    Crash recovery
    In the unlikely event that your phone stops responding
    to taps and key presses, try a quick reset. Remove the
    back cover and battery (“Assemble & charge” on
    page 3), then replace and switch your phone on as
    usual.
  19. #19
    Default
    It annoys me that people are so gung-ho about jumping on the "the droid is not a blackberry" bandwagon... WE KNOW THIS. IT WAS OBVIOUS WHEN IT WORKED OUT OF THE BOX!
    but seriously... SOMETIMES, it is pretty necessary to pull the battery (i do like gbhil's suggestion though!)... I've had a few of these times, especially when i was monkeying with rooting and customizing the phone this weekend. I've also experienced it a few times when swype (the app I don't have *wink wink*) blew up...
    So here is my suggestion if your phone freezes up...
    1. Try holding down the power button and rebooting, if that doesn't work...
    2. Try holding down ALT+SHIFT+DEL and rebooting, if that doesn't work...
    3. Follow gbhil's suggestion, if that doesn't apply, you don't have a computer nearby or if it just doesn't reboot (i've had a few instances I couldn't force reboot from my computer)...
    4. Pull that battery. OMG DId He juST SAY that? yes... i did.
    You only wish you were Droidin' like me
    They see me Droidin', they hatin', my Big Red. Never gunna catch me rockin iPhone.
    Smoke Signals -> Rotary -> RAZR -> Droid
  20. #20
    Default
    Tell that to Verizon Technical Service...as I had my phone in recently when the tech was about to perform a battery pull on my phone...I asked the tech that shouldnt you turn off the phone first before pulling battery? The tech just shook his head and continued to pull the battery. I asked whether or not it would damage the phone and the tech said it would not damage the phone at all. The tech also said that a battery pull with the PHONE ON is the only way to perform a battery pull when toubleshooting phone.
  21. #21
    DeeMat's Avatar
    Posts
    Global Posts
    282 Global Posts
    Default
    Quote Originally Posted by stuckingoo View Post
    For a Droid, possibly yes (last resort). For a BB, it's the only way to make it work (for a few hours at a time )
  22. #22
    Default
    Hold CTRL+ALT+DELETE if you want a 'clean' restart.
  23. #23
    j-radcapp's Avatar
    Posts
    Global Posts
    49 Global Posts
    Default
    Amen to that!
    I pulled that battery out so many freakin times!
    Only once on my DROID!
  24. #24
    Default
    reboot -n
    Google didn't license "Droid" from Lucasarts, which makes the Moto Droid better than Nexus One.......
  25. #25
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    I'm surprised the OP never followed up with any sort of explanation. While their is a lot of good information in this thread, the case for not doing a battery pull was never made IMHO.
