Results 1 to 12 of 12
    Default How do I unlock phone without using touchscreen?
    There has to be a plan B built into this phone that I love so much. My touchscreen just stopped working and there is no way to unlock it using the D-pad? I have tried soft reset in a number of ways and no luck. Please hurry, before an i-phone person see's my droid is not working!
  2. #2
    Default
    The touch screen is broken? I believe you're SOL til you get a new phone then...
    Matt
    Current Phone:Motorola Droid
  3. #3
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    1,935 Global Posts
    Default
    SusanHome -- See my post in your previous thread.
    If you are not password protected, and use the default lock app the magnet thing I talked about in your other thread will work. I used a small round magnet on my test, and it worked fine.
    Thanked by:
    jhismo
    Default
    I tried the magnet which worked to unlock the phone...thank you. However...it is almost impossible to navigate the phone from the keypad. UGH! On to my own plan b!
  5. #5
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    1,935 Global Posts
    Default
    What is plan b?
    Where you able to get your text msg? You wont be able to really use your phone with just the d-pad but you should be able to read that one text you wanted to read
  6. #6
    Default
    Question.... Why was this started as a new thread? One of the main reasons I like this forum is that it is uncluttered. I'm not a moderator and not trying to police it or be mean to a new member .... but please!!! what was the point of starting this new thread?
    Exact same issue, same member, 2 threads started (insert disgusted sigh here)... that's just.... annoying.
  7. #7
    Default
    root, install sprecovery, backup system. Then steal someone else's droid and restore your image.
  8. #8
    Default
    Or you could install one of the custom 2.1 releases...if I remember correctly one of them had a bug where if you slid open the keyboard it unlocked the screen.
  9. #9
    Default
    Quote Originally Posted by PJnc284 View Post
    Yes. Lets root and break the warranty so he has to pay in order to replace his phone.
  10. #10
    nox
    nox is offline
    nox's Avatar
    Retired Super Moderator
    Posts
    Global Posts
    1,370 Global Posts
    Default
    Quote Originally Posted by CyD13 View Post
    Or you can revert back to stock so he never broke his warranty.
  11. #11
    Default
    exactly. root, backup, unroot/restore to default 2.0.1 and return. Which can all be done easily without using the touch screen. Then root and restore the image on the new one. There are backup apps in the market for sms, etc but I'd hate to try any of that with a borked screen.
  12. Thread Author  Thread Author    #12
    Default
    Thanks everyone! The magnet was a great idea, except the keypad only gets you so far. Verizon and Motorolla have never geard of the screen not working...Verizon is sending me a new phone.
    And Prometheus...sorry to be annoying to you. It was late, I was frustrated and on several chat/forums.
