Results 1 to 5 of 5
- 02-03-2010, 09:19 PM
Thread Author #1
Battery use then force close!! HELP!
On my droid I was able to view my battery use but now I get the following:
Sorry!
The application Settings (process com.android.settings) has stopped unexpectedly.
Please try again.
Force close
I try the next day or even a couple hours later and this keep happening. Is there a way to fix this or what would I need to do?? - 02-03-2010, 10:09 PM #2
Is your phone rooted? If so it's the last thing you did
There's really no way to tell why.
If your phone is not rooted or modified, have you tried rebooting it?(•‿•) - 02-04-2010, 11:11 AM #3
If your rooted, you have yourself a con of worms. If not, do you have any 3rd party app manahers/killers? Or 3rd party battery monitor programs? Get rid of them...
Droid---[ROM] Bugless Beast V1.0, Nextheme, Bekit 800mhz kernel!
Proper Prior Planning Prevents **** Poor Performance! - 02-04-2010, 02:54 PM #4
are you running a task killer? if so, be sure to ignore system processes. yet one more reason to NOT use task killers they kill stuff that screws up basic operations.
- 08-12-2011, 10:35 PM #5
Reply
