Results 1 to 19 of 19
    ethan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Earpiece Problem
    I'm having a weird problem where when I make a call, theres no audio coming into the earpiece on the phone. Apparently people on the other end can hear me, but the earpiece on my phone doesn't work. This only happens sometimes. Any ideas?
  2. #2
    GenericMessage
    GenericMessage's Avatar
    Guest
    Default
    Get a new phone.
  3. #3
    willymakit's Avatar
    Posts
    Global Posts
    934 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock
    Default
    Quote Originally Posted by GenericMessage View Post
    Get a new phone.
    10,000 comedians out of work and your trying to be funny.
  4. #4
    CharlieL3's Avatar
    Banned
    Posts
    Global Posts
    335 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Actually, get a replacement phone.
  5. #5
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I read this one other time, and another symptom was that the headset icon displayed, even though the headset wasn't plugged in. Did you happen to notice that or not?
    If it were me, I would
    1.) Suspect 3rd party apps.
    2.) Hard reset.
    3.) Hardware issues: return it.
  6. #6
    Jeremy's Avatar
    Original Member
    Posts
    Global Posts
    10,099 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Cory Streater View Post
    2.) Hard reset.
    I agree with a issue like this always a perform hard reset before going into a store. Chances are that's the first thing they will end up trying anyways.
  7. #7
    Kaizmuth's Avatar
    Posts
    Global Posts
    133 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I've found that my headset (bluetooth Plantronics Voyager Pro) tends to do this when the battery gets low. Works great other wise. If it happens, I call the person back, it works fine; but invariably the battery in the headset is low.
  8. #8
    scodoublet's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Any chance you have your ringer muted at the same time you're having this problem? For some reason my Droid had the Earpiece volume linked to the ringer volume. When I would try to turn up the volume of the ear piece in-call it would appear that it turned up but the sound would not go up at all.
  9. #9
    prometheus's Avatar
    Posts
    Global Posts
    2,205 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I know this sounds like a stupid suggestion.... but, I always go for the most obvious solution first. Sorry, if this insults you...
    but, are you aware that the while on a call the volume rocker increases / decreases the headset volume?
    You stated that they can hear you and you have trouble hearing them, But, this only happens sometimes. The volume setting for calls can be set to a default volume or to "last call" volume. Perhaps your default is good but every once in a while your actually pressing the volume rocker with your thumb while holding the phone on a call.
    I've noticed my thumb goes right where the down volume buttom is if I'm holding the phone with the right hand. Maybe you have the default set OK, but, every once in a while due to holding the phone with your thumb on the volume down switch your actually just turning it down.
    While the phone is pressed to your head and the volume is being turned down by accident you can't see the screen which is diplaying the fact that volume is being turned down - therefore, you assume it's a malfuction. Try adjusting how you hold the phone.
    Sorry, if that seemed like I was talking down to you. "why is my volume low?" "uh, you turned it down." I just find that 9 times out of 10, the problems I have are user error.
  10. Thread Author  Thread Author    #10
    ethan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I don't think I'm turning it down, as far as I can tell. The problem isn't with an external earpiece, it's with the one that's built into the phone, and it seems to only happen sometimes.
  11. #11
    scodoublet's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by ethan View Post
    Is your ringer volume turned down when you have the earpiece problem? That happened to me before.
  12. Thread Author  Thread Author    #12
    ethan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    No, I'm pretty sure it's not turned down.
  13. #13
    kennyidaho's Avatar
    Posts
    Global Posts
    169 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by prometheus View Post
    Well I don't know how the OP feels about this but I am highly offended! How dare you talk to me like that - do you talk to your mother with that filth?
  14. #14
    woahboi's Avatar
    Posts
    Global Posts
    35 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i had this issue sometimes when i was using a bluetooth device and then turned the device off but did not turn the bluetooth off from my phone. seems odd to me but i just have to turn off bluetooth connectivity and all is well
  15. #15
    Flyguide83's Avatar
    Posts
    Global Posts
    305 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Mine does this too and I have figured out what causes it. first I should say that it can be fixed with a reboot. if I have anything plugged into the headphone jack and have anything playing audio phone call or music, I have to pause it before removing the headphone plug. Otherwise, the earpiece speaker will not work.. if I pause the music then remove it, the speaker will work fine.If I put call on speaker phone then unplug the headphone jack, its fine..very strange and I can replicate the issue every time... hmmm, wonder if I am the only one with this issue...
  16. #16
    benthomas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'd just like to let you know that I am having exactly the same issue as the original poster. I haven't really looked too much into why but I have tried ending apps one by one before trying again to see if I can find the cause. Sometimes I'll go days without it happening, other times it will happed regularly. It's really frustrating because when someone calls me, it's fine.
    9 times out of 10, if I use an app to 'end all' of my apps it will work again.
  17. #17
    Zookeeper's Avatar
    Posts
    Global Posts
    27 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Sorry I can't post urls yet but there is this application you can run when your audio gets messed up. Doesn't matter what causes the audio to get goofy this application will fix it.
    alldroid.org/threads/15058-[RELEASE]-fix-audio-after-disconnecting-headphones-AUX-cable
  18. #18
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    2,067 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Flyguide83 View Post
    Mine just started to do this late last week. I do find that a reboot fixes it, but that is anoying as hell.
    I am always listening to my MP3's or Pandora through a radio in my office or my car via a cable plugged into an AUX port. I almost never manually pause my music when I need to move to a different location and unplug the phone. I will start pausing before I unplug to see if my problem goes away.
    Thanks for your post.
  19. #19
    Muratboynu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Earpiece Problem
    I have a similar problem where earpiece does not work but speaker and headphone works. If I pressed the phone hard onto my ear, I could hear the sound through earpiece, I had fixed the screen before so something must be loose inside.
