Results 1 to 21 of 21
    ryobi43's Avatar
    Posts
    Global Posts
    54 Global Posts
    Default Anybody had this problem?
    My droid had no volume during calls this morning. The only way to hear was to place on speaker phone. Like that for a while and now is working. Just wondered if anybody else has experienced this.
  2. #2
    Chris Kerrigan's Avatar
    Posts
    Global Posts
    4,182 Global Posts
    Carrier
    Stock
    Default
    Do you have any sound profile apps installed? First thing I would do is check any apps you have installed recently, as one of them could be the culprit.
    Second, I would try powering down and restarting your Droid. See if that helps and if the problem persists.
  3. #3
    thebizz's Avatar
    phone addict
    Posts
    Global Posts
    3,825 Global Posts
    Carrier
    mean
    Default
    No I haven't this is the first u heard of this bug. That's crazy how does your phone have volume now or are you still using the same hack
  4. #4
    Dapke36's Avatar
    Posts
    Global Posts
    619 Global Posts
    Default
    Mine did not have this problem. Actually I had the reverse, mine was on full volume. THat was probably my fault, however.
  5. #5
    Default
    I have this a couple times each week but Ive never tried to turn on the speaker phone I just shut the phone off completely and turn it back on.
    Just a thought, do you have any emulators on your phone? (nes, snes, etc.)
  6. #6
    dubge's Avatar
    Posts
    Global Posts
    1,384 Global Posts
    Carrier
    Always changing
    Default
    I had this happen 2-3 time on Sat. to me when receiving a call, it was the first time it has happened and all I did was hang up and call back and it was fine. I did notice that I had signal, like 3 bars but it did not show 3G or 1X but when I called back it showed 3G and 3 bars. I did not try to put it on speakerphone
  7. #7
    Default
    I have not had this problem, but my volume for the media keep getting reset to zero.
  8. #8
    Jared DiPane's Avatar
    Posts
    Global Posts
    7,367 Global Posts
    Carrier
    Stock
    Default
    You could have a defective speaker in your headset, which would be why it worked during speakerphone, but does not work regularly.
  9. #9
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,544 Global Posts
    Carrier
    NOS M7 Sense 5.0
    Default
    Never, had a few calls with the volume really low then just end the call and call back then the problem is gone (bad connection).
  10. #10
    Default
    happened to me twice the other day, restarted the phone and everything was great again..
    emdee81
  11. #11
    Default
    I had this problem too -- I found elsewhere on the web that this can happen if you are listening to music with earphones and pull out the earphones before stopping the music player. apparently the phone gets confused (pardon the terminology; clearly I'm not a techie) and thinks that the earphones are still plugged in, which is why you aren't hearing anything on the call. resolve by either restarting or doing a battery pull. adn turn off the music before removing your headphones going forward -- I haven't had a problem since I started doing that.
  12. #12
    CharlieL3's Avatar
    Banned
    Posts
    Global Posts
    335 Global Posts
    Default
    Restarting is fine. If the phone is responsive, a battery pull is never needed on the Droid.
  13. #13
    Default
    Quote Originally Posted by CharlieL3 View Post
    good to know. is there a reason to avoid doing a battery pull; i.e. is it bad for the phone/battery?
  14. #14
    Default
    I haven't had this problem with my Droid, but I remember having this problem when I had a moto v551 way back in the day......I had 4 different ones before they finally let me switch.
  15. #15
    Default
    Unfortunately this is a problem with some smartphones from what I've seen and experienced. It usually occurs when listening to music via the headphone jack (whether using headphones or a stereo cable). During music play or even after, unplugging the cable from the jack leaves the phone in this state (speakerphone only mode). As a result I've developed the habit of checking my phone everytime I unplug my headphones. To do this I simply click the volume up / down button and listen for the beep. If no beep, I know it's stuck in speakerphone only mode. So all I do is launch the music player and an mp3, then plug in my headphones (or aux cable) in and out of the jack which usually clears it. I've had one instance where it didn't clear and I had to reboot the phone but that was only once and 8 out of 10 times I don't have the problem to begin with.
    I knew about this little 'fix' because one of my previous phones (iphone 3g) had this issue and the fix was the same. The Pre had lots of complaints about this as well with the same solution.
    I've also noticed that my other pair of headphones that have 3 rings (four segments) on the jack itself fits snuggly and don't seem to cause this problem. Unfortunately its performace is subpar so I end up using another pair with better bass. However it's this pair that seem to cause this issue (it has the normal 2 rings with 3 segments on the jack itself). So simply changing the headphones can probably be a workaround for this problem.
  16. #16
    j7469's Avatar
    Posts
    Global Posts
    768 Global Posts
    Default
    Quote Originally Posted by Dapke36 View Post
    Quote Originally Posted by jasonrellis View Post
    I've had both of these happen to me every once in a great while. I just chalk it up to a 3rd party app. Every time a reboot fixes it.
  17. #17
    CharlieL3's Avatar
    Banned
    Posts
    Global Posts
    335 Global Posts
    Default
    Quote Originally Posted by banba1 View Post
    It isn't bad for the battery or the phone, but it isn't necessary to pull the battery unless the phone is completely unresponsive. Powering down and restarting the phone is sufficient, pulling the battery won't do anything more for the phone than that.
  18. #18
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    2,067 Global Posts
    Default
    1st I've heard of this problem. Hmmmmm....
  19. #19
    Zookeeper's Avatar
    Posts
    Global Posts
    27 Global Posts
    Default
    please read this thread. (sorry I can't post links yet)
    "droidforums.net/forum/tech-issues-bug-reports-suggestions/9648-official-thread-no-sound-after-headphone-use.html"
    Towards the end of it there is a link to this application that fixes audio problems. This works great on both of my Droids when they get goofy.
    "alldroid.org/threads/15058-[RELEASE]-fix-audio-after-disconnecting-headphones-AUX-cable"
  20. #20
    Default
    Quote Originally Posted by darreno1 View Post
    This seems like it's becoming a more common problem:
    The Official Thread for No Sound after HeadPhone Use - Droid Forum - Verizon Droid & the Motorola Droid Forum
    (sorry, I can't post links yet, either)
    I was having the same issue - after unplugging an AUX cable from the headphone jack, I was not getting any audio through the earpiece while on calls. Speaker and headset would work fine, though. I couldn't get sound through the phone playing video or music either when it was in that state. It seemed like the phone didn't register the headphone jack being unplugged. A soft reset would fix the issue.
    After reading the above thread on DroidForums, I called Verizon. The rep paused a bit to "check if it's a known issue". After less than a minute, she asked if I had my contacts backed up. I could tell where this was heading, so I let her know I had already tried a hard reset, and the problem persisted. Without hesitation, she arranged for a warranty replacement (I'd had the the phone for about 90 days, but the warranty on the phone is one year). I was going to be out of town when the shipment was scheduled to arrive, so she checked my local store, and they had plenty in stock, so the store swapped my phone for a refurb with no questions asked.
  21. #21
    Default
    I have this low volume on incoming calls problem intermittently--but I'm never listening to 'phones prior to the call, so that isn't it. In fact, in many cases the phone is just sitting there, doing nothing. I can barely hear the caller (if it's otherwise quiet around me), and I ask them to call back. The next call is always OK.
    Very annoying.
