1. kheeder's Avatar
    Hi, sorry for the english
    Just bought a droid an it worked fine
    Installed a couple of apps and the following happend
    All apps detect the position of the phone except the original homescreens
    these are staying always in portrait except if in the dock or the keyboard it sclided out.
    I switched the phone on and off but same behavior.
    Any idea what I can do the get it back.
    I did set the switch correctly in the Sound and screen
    Any help is very appreciated.
    Klaus
    03-10-2010 05:52 AM
  2. Argodabar's Avatar
    The homescreen does not turn if the keyboard is not out.
    03-10-2010 06:41 AM
  3. kheeder's Avatar
    Yes correct but it did until yesterday. The question is why did it stop?
    03-10-2010 07:20 AM
  4. myriad46's Avatar
    Loose keyboard? Maybe you were inadvertantly sliding the keyboard slightly when you turned the phone sideways...
    03-10-2010 07:55 AM
  5. Chris Kerrigan's Avatar
    That is what I was thinking. The phone will go into landscape mode on the homescreen if they keyboard is even SLIGHTLY slid out, it doesn't take much at all. Otherwise the, it will not switch to landscape mode on the homescreen.
    03-10-2010 08:23 AM
  6. kheeder's Avatar
    OK understood. I will just add a different Homescreen than.
    Thanks for the answers
    Klaus
    03-10-2010 09:28 AM
