Results 1 to 5 of 5
    Question Battery status?
    We have two i1's and both seem to only report real battery status while charging. The rest of the time they always report 100% charge. Anybody else having this issue?
  2. Thread Author  Thread Author    #2
    Default
    Well today it moved from 100%, but it dropped all the way down to 65% and then went to 35%. Very hard to tell what charge the battery really has in it!
  3. #3
    Default
    try installing the maintenance/bug fix update.
  4. #4
    Default
    Quote Originally Posted by MotoDroid View Post
    The update does not fix the % value and it won't as this is a rom issue
    Sent from my Optimus V vai Tapatalk
    Maybe the main purpose your alive is to serve as a warning to others~
  5. #5
    Default
    jus a suggestion to try.
