Results 1 to 7 of 7
- 07-18-2011, 07:26 PM
Thread Author #1
When phone flips to side when Messaging the Send becomes "Done"
Ok none my other android phones I've had does this and I can't figure out if there is a way to change it or if this a Motorola thing but is VERY annoying.
Why when messaging and the phone is up it shows the Send button, but when you flip it over to the side which I prefer to type with it turns into the Done button???? its so annoying to have to hit done then send again. No other android phone I have had has done this?? Any idea's ???
And yes it doesn't matter what keyboard I use, or even if I download a different keyboard its still there.
Thanks for your help - 07-18-2011, 07:53 PM #2
- 07-19-2011, 03:27 PM #3
- 07-19-2011, 03:43 PM #4
Re: When phone flips to side when Messaging the Send becomes "Don
- 07-19-2011, 06:17 PM #5
I use GO SMS Pro and it does not do this, send is there no matter what the orientation
Google+ Devices: HTC Mogul, Touch, TP, TP2, Samsung Moment & Intercept, Motorola Triumph, LG Optimus V & Slider, Nook, Iconia Tab, HTC Sensation - 07-20-2011, 06:06 AM #6
- 07-20-2011, 08:48 PM
Thread Author #7
Reply
