Results 1 to 5 of 5
- 08-01-2011, 12:47 AM
Thread Author #1
Volume on your headphones too low? Try this.
I copied this over from my reply at Howardforums and thought I'd share it here.
I noticed if you make a phone call while listening to music then hang up, the music will get exceptionally louder..almost too loud. And when you get a text the music will get quiet. So put your phone on silent when you're listening to music. Also, when you close the music player it will reset the loudness. I just call VM CS number so it doesn't waste my minutes... Let it ring once or twice otherwise it won't change..theres a jerry rig fix until custom rom I guess.
Edit**
I can confirm this works with Pandora too.
Sent from my MOTWX435KT using TapatalkLast edited by Godbilla; 08-01-2011 at 12:53 AM.
Thanked by 2: - 08-01-2011, 12:25 PM #2
- 03-02-2012, 12:26 PM #3
- 03-02-2012, 08:01 PM #4
I also noticed if you have google music and the standard music app installed and switch between the two it will reset the volume. This worked for awhile but it didn't seem to work today.. no idea why.
Sent from my Triumph using TapatalkMy Google+ Account: http://plus.ly/justinsterling - 06-16-2012, 02:01 PM #5
Re: Volume on your headphones too low? Try this.
Thanks TONS!! This workaround works for WinAmp too. I ripped my mp3's with 100% volume and they played great in my old OV. My new MT played them at about 70% of that. My Pink Floyd stuff sucked at that volume! I also have acoustic Bob Dylan. He was too low to hear at all! Now all my old "hippie tunes", as my kids call them, sounds great! Peace & Love !
Reply
