Hi there!!! As a right to you on my iPad, in June, my contact with T-Mobile is up, and I am going to HAPPILY switch to Virgin. Right now I have unlocked an iPhone 3G (yes.... Old!) and I really actually like it, despite it's slow and sometimes unresponsive. I was wondering if the screen on the triumph is as hard as the iPhone is. I had an old Samsung that I had to use temporarily, and I hated it. It was unresponsive, and the actual screen I could break when pushing it (with anger), because it was a flimsy plastic. The last thing I want when I make the jump into the unknown waters is having a flimsy plastic screen! Is it like the ones on display? I don't think it would be, because I think those are removable and you can change out the backs.
Thanks for reading the first chapter of my novel XD, and I can't wait to hopefully hear some responses!
Alex
Alex
