1. zackca's Avatar
    As my title says, I recently had to buy a new Triumph due to the charging port being broken, and I saved a lot of my apps on my SD card, but I don't know how to reach the apps on the memory card. When I open the menu of all my apps, it only sees what has been installed on the phone, does anyone know how I get it to recognize the apps on my memory card? Any help is very well appreciated, I'd love to get back to work on all my games!
    Thanks!
    - Zack
    07-28-2012 05:10 PM
  2. swwhite's Avatar
    First, I would try clearing the data for each app. Then if that doesn't work, I think you need to just reinstall your apps.
    Sent from my Triumph using Xparent Cyan Tapatalk 2
    08-10-2012 12:48 AM
