Results 1 to 12 of 12
    piiiiiink15's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Motorola Triumph suddenly won't charge on the charger ? (2)
    *In continuation of my last thread of my charging issue*
    Not to sound stupid here or anything but just so I do not make a mistake in trying to fix my phone's charging issue, what are the tension clips on the male (charger end) charger ? All I see are the 5 little metal bars and that's it...am I supposed to lift those? I'm still sort of confused on what to actually "pry up" ?
  2. #2
    poweredge99's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP Beta 2 (thanks TDM)
    Default Re: Motorola Triumph suddenly won't charge on the charger ? (2)
    It's the two tabs that are on the outer part of the charger and face up when put into the phone. They lock in to hold the cable in. I just slightly pryed them up a little at a time until it worked.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay so I take a sewing needle and lift up those 2 tabs? how much do I lift them up? Like until the tabs are lifted above the surface ?
  4. #4
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    You got it. I did.... maybe 1/32 nd of a inch at a time. And kept checking after each to see if it worked. Also, I had it unplugged just in case each time I adjusted it. Not sure if I would get shocked of not.
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Hopefully that fixes it. Just be careful not to ruin it by going to far.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks so much, it seems like it is not draining at the moment, but I hope it's not a fluke ya know? How often should I do this and do I have to do this to all my chargers that I use for my phone?
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    If it fixes it you can. I didn't. I just use the one usb cable in my home and car. Hope that fix works for you.
  8. Thread Author  Thread Author    #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    oh okay.....well was your phone having the same issue as me? like would your phone light just randomly turn off as it's on the charger?
  9. #9
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Yeah. Then it just stopped charging all together. Now it's doing well and been two weeks with no problems. My wife's has no issues and is older then mine.
  10. Thread Author  Thread Author    #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh really? And it drained on the charger too? My phone is still doing the same thing, like the red light is still turning off randomly at like 49%....it's a brand new battery so it's not that it's not capable of getting to 100%, should i move the tabs again or a little higher?
    Also, i thought it was strange that when I got my new battery and I plugged it into my phone, it started charging at 60%.........that's weird
  11. #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Adjusting it higher is up to you. I have many other charging cables so I was a little less concerned about damaging one. If you wiggle the cable does that effect the light? You have to hold it a sec in a position to let it register. If that doesn't work out it maybe another issue and that would be above my level of knowledge unfortunately.
  12. #12
    Aalliyah81's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine either , i was wondering do the Motorola Triumph has to charger spots at the bottom ?? because no other charger isnt working with it .. so im trying to see is the little slot on the left a charger or not (: .. please help ..
  1. Motorola Triumph suddenly won't charge on the charger ?
    By piiiiiink15 in forum Motorola Triumph on Virgin Mobile
    Last Post: 01-16-2013, 03:59 AM
  2. Triumph Battery won't charge when the phone is on
    By cktp4400 in forum Motorola Triumph on Virgin Mobile
    Last Post: 08-29-2012, 11:48 PM
  3. Video Review - Seido Vault - Charging on the go!!!
    By gobluejd in forum Thunderbolt Accessories
    Last Post: 10-18-2011, 10:44 AM
  4. Apps that WON'T install on the Atrix...
    By ivantwilliams in forum AT&T ATRIX
    Last Post: 02-24-2011, 06:44 AM
  5. Replies: 10
    Last Post: 07-14-2010, 04:54 PM
