Results 1 to 6 of 6
    Stang68's Avatar
    Posts
    Global Posts
    5,130 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default What's the difference between themes and ROMs?
    Hey everybody,
    I just rooted my Droid X and am looking to possibly customize it a little. I use Launcher Pro Plus and love it but I see some really interesting themes/ROMs out there and thought I would give it a try. What is the difference between the two? What is a theme and where can I find them? Same for ROMs...where can I find them and how difficult is it to install?
    Thanks!!
  2. #2
    doctorlove316's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,258 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I would try ROM Manager first.
    A theme just takes the existing setup that you're running and replaces the apps with the same ones, but themed. Such as status bars, pulldowns, menus, colors, some applications (can't theme them ALL), fonts, and things like that.
    A ROM is a little more complicated. Here's a link for more info Custom ROMs For Android Explained And Why You Want Them - Android Police
    cloud92 likes this.
    Stang68's Avatar
    Posts
    Global Posts
    5,130 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks!
  4. #4
    MikeFlu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: What's the difference between themes and ROMs?
    So, you can install a theme over the top of a ROM?
  5. #5
    PappaFloyd's Avatar
    Dab King
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BAKED 4
    Default
    Quote Originally Posted by MikeFlu View Post
    Absolutely.
    Sent from my DROIDX using Tapatalk 2
  6. #6
    jerseyboy357's Avatar
    Posts
    Global Posts
    1,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Liquid Smooth JB Beta 2
    Think of it like this:
    Cellphone - ROM
    Computer - Windows/Linux/Chrome
    Theme is just how it looks, sounds and "feels"
