DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 8 of 8
    MHB1638's Avatar
    Posts
    Global Posts
    54 Global Posts
    ROM
    2.0 with -50 PBJ
    Default Need help!
    Ok, so I've been reading all these threads and non of it is actually working on my phone. The problem: Wife's DX locks up on any form of typing-facebook, SMS, email, market, etc. In the middle of typing it just closes out. So, I figured I'd redo everything on it to see if I can fix it. I've downloaded a million files so far, nothign is working as the threads state:
    http://forum.androidcentral.com/moto...ctions-gb.html
    And the thread here from step 1 to complete from froyo up. Wife's phone is currently:
    4.5.588.mb810.verizon
    2.3.3
    BP_c_01.9.12P
    2.6.32.9-g0bae333
    4.5.2_57_dx5-18
    I've downloaded and bought drop 2 bootstrap. I've downloaded SBF, z4, rsd, etc. When I follow the instructions, I get into bootloader, start RSD, find the file, but RSD never see's the phone connected. At least it never does when it's off. If it's on I can see it and access the SD. I did enable debugging too. So, IDK what else to do. I have tried to access recovery but it fails...power + home..quickly shows a unboxing icon then the little android toon with a triangle with exclamation point. Nothing else after that. Any ideas?
  2. #2
    kismet769's Avatar
    Posts
    Global Posts
    326 Global Posts
    ROM
    Synergy
    Default
    This is what I had to use to get GB on my phone.
    Also, there's a new sbf program out...
    That should help
  3. #3
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    SKAnkCM10/Milestone6
    Default
    Quote Originally Posted by MHB1638 View Post
    2.3.3
    BP_c_01.9.12P
    2.6.32.9-g0bae333
    4.5.2_57_dx5-18
    Factory reset might help
    Sent from my DROIDX using Tapatalk
  4. #4
    Default
    Latest drivers from Moto?
    MHB1638's Avatar
    Posts
    Global Posts
    54 Global Posts
    ROM
    2.0 with -50 PBJ
    Default
    It's workign now, as suggesting I did a factory wipe and started the whole process. Only problem I may have is z4root. I clicked on it, its in the "working" stage saying running exploit in order to obtain root access at bottom, but its been at least 10 mins and still working. Thinking its bugged...
  6. #6
    Default
    Try un-installing Z-4, then re-install. But reboot after the install before you try to run it.
    MHB1638's Avatar
    Posts
    Global Posts
    54 Global Posts
    ROM
    2.0 with -50 PBJ
    Default
    Quote Originally Posted by .46caliber View Post
    I backed out of it and restarted it, worked perfectly, I'm now installing the 588 "parts". Thanks for the replies and help!!
  8. #8
    Default
    z4 always gave me that hiccup as well. when you get to .595 don't forget to grab the xda netflix app too!
