Results 1 to 6 of 6
    Default Dead or disconnected battery?
    My Xoom suddenly died last night. It hadn't shown a low battery indicator, but it seemed as though it was out of power. I hooked it up to my plug-in charger, and it booted back up. At the log-in screen, the second line was flashing and indicating that battery charging was a 84%.
    I used the Xoom for a while while it was plugged in, and it worked fine. Then, as soon as I unplugged it, it died again. I plugged it in, booted it up, and left it to recharge over-night, as it was getting late.
    This morning, the login screen still had the flashing charging at 84% message. While plugged in, my Xoom ran fine, but teh instant it was unplugged, it died.
    I booted up holding the "volume up" button, and got the message:
    "Starting RSD protocol support 0
    OneWire: Charger is not connected or battery is not being charged...
    Battery charge level: 84%"
    Is this an indication of a dead battery? And what's with the constant 84% charged indication. If it's a 84%, shouldn't it run?
    If I looking at a dead battery, is this a Verizon Store serviceable issue, or is it going to be a "send it back to Moto" deal?
    Very pissed,
    slwerner
    Attached Thumbnails Attached Thumbnails Dead or disconnected battery?-2011-11-18_06-06-16_177.jpg
  2. #2
    dhendriksen's Avatar
    Android Addict
    Posts
    Global Posts
    1,651 Global Posts
    Default Re: Dead or disconnected battery?
    I'd call Motorola. Good luck.
  3. #3
    Castorshells's Avatar
    Posts
    ROM
    Tiamat 2.1.0 Manta Ray
    Default
    Yeah your gonna need a new batt most likely. I would call moto, you should be abke to get that replaced or something.
    Xoom+Root = Perfect Match
    Quote Originally Posted by Castorshells View Post
    Turns out it was some sort of "stuck-on-stupid" Xoom trick.
    I talked with Verizon tech support, to no avail. I was about to contact Moto, when I decided to try one more possibility.
    I had a new charging dock which I received with my LTE upgrade. After my original dock suffered the fatal charging pin spring failure, I had gotten away from using one, so the new one was still unwrapped.
    Anyway, since I had tried both of my charging cables and had not gotten the battery to charge/function to keep myXoom running, I wondered if the issue might have been that the charging plug receptacle had become disconnected internally. I intended to test this possibility by using that new charging dock, which would apply charge to the external contracts.
    Well, when the charge status ceased to blink 84% and started to display a steady and increasing value, I thought I had figured out my problem.
    I resolved to contact Moto and tellthem about what I thought I'd figured out...but decide to make sure - so as to not endup looking like an *****. I pulled my Xoom off the charging dock, expecting it to die...but it stayed on.
    It was showing 90% charged at that point, so I decided to run it back down to 84% to see it it was at that level that it would again spontaneously shut off.
    But, when it did get below 84%, it kept running. Rather perplexed, I let it continue until it displayed the low battery indication. Then, still convinced that I knew that it was a charging plug issue, I plugged it in directly using the cable.
    But, instead of not charging, it indicated that it was charging. In abouthalf an hour, it was again fully charged.
    I have since tried letting it run- down and recharge a couple more times, and it has neither shut down nor failed to charge.
    I have no explaination for what happened. And I continue to expect it to happen again. But, for the moment, all seems well.
    I'm wondering if this wasn't just another weird and random one-time occurance, much like the time it was failing to turn on, and after several attempts to use the "volume up-power button" combo, it finally worked and has never had that problem again.
    All I can think of to describe it was that it was just "stuck on stupid"...again.
  5. #5
    I'm having the exact problem you describe in the OP. However, I don't have a recharging dock, so I currently can't try the "fix" that worked for you. I can go out and get one, but I wonder: Did the problem ever recur, or did that one time "fix" do it?
    Thanks.
    Yes, it did re-occur - multiple times.
    I eventually set it to Moto for repair. But, I did discover a "fix" that worked in my particular case. If I pressed firmly on the front bezel near the point that the power contacts would be, with a little bit of "fiddling", I could get it to power back on. This lead me to believe that there must have been a loose connection internally somewhere near the point where the connectors for power were.
    Moto repaired it under warranty, (no charge, they paid for over-night shipping both ways). But they never gave me any indication as to what it was that they fixed. I used the support on-line chat to inquire what repairs had been made, but the customer rep I dealt with told me that even they do not have any information on specific repairs to any units, as a matter of company policy.
    I thought that it had to be one of the stupidest policies I'd ever encountered (I'm pretty sure there would be no wide-spread panic in the streets if some systemic issue with Xoom's became public knowledge).
    However, my Xoom has worked perfectly since they repaired it, so I would advise you to have them repair it if your warranty is still in effect.
