Results 1 to 4 of 4
- 11-20-2011, 11:49 AM
Thread Author #1
Xoom Root problem Please help
Hello all, i have had my xoom since launch and rooted it shortly after using the first one click method. It installed the Tiamat 1.1.6 kernal on my xoom. That kernal is still on there and i am running stock 3.0. Recently my Superuser app stopped giving permission to my apps. i couldnt figureout what was wrong so i tried uninstalling Su app but that also falied. So now i am stuck with no root privlages but my device still thinks its rooted some how because i cant update. i tried updating but it gets about half way thru and stops. I want to unroot my device so i can update but i dont know what method to use because i am afraid my device will brick because my Su doesnt give permissions and therefore my device isnt technically rooted. All I am looking for is a way to get the Su application off of my xoom and be completely unrooted so i can update. Please respond with anything that may help. Thank you.
- 11-20-2011, 12:45 PM #2
- 11-20-2011, 02:53 PM
Thread Author #3
- 11-21-2011, 08:43 AM #4
Re: Xoom Root problem Please help
If you want to go completely back to stock do this: [Guide] Unroot and re-lock Xoom via fastboot and official system images
Or, if you want to just re-install the su binary and the superuser app flash this zip through recovery.Fred
@thefredelement
Reply
