Results 1 to 25 of 72
- 01-10-2012, 08:21 AM
Thread Author #1
Xoom LTE soak test on the way
got this in my inbox this morning
Hi.
Thanks for joining the Motorola Feedback Network. We may have a small project for owners of Motorola Xooms on Verizon. Participants must have had their Xooms upgraded to LTE to take part.
At this point, we can't positively confirm that the project will go forward, but if it does, the timing will be fast and we thought it best to prepare a group to provide feedback.
So, if you can live with some uncertainty, please take a moment to sign up here.
Thats all the information I have to share at this time. If you sign up and meet the conditions of the project -- and it actually goes forward -- more will be provided.
Regards, - 01-10-2012, 08:25 AM #2
Re: Xoom LTE soak test on the way
Hopefully it means ICS will be coming soon. But I wouldn't hold my breath.
- 01-12-2012, 03:58 PM #3
Looks like the ICS "soak test" for the Transformer Prime has been to release the upgrade generally, then try to figure out what issues users will end up having:
http://forums.androidcentral.com/asu...cs-issues.html - 01-12-2012, 07:07 PM #4
- 01-12-2012, 08:12 PM #5
- 01-12-2012, 10:29 PM #6
- 01-13-2012, 08:36 AM #7
Anyone else received one for the LTE version? I've been in the MFN for a while and didn't get an email.
Sent from my DROIDX using Tapatalk - 01-18-2012, 01:27 PM #8
I guess everyone is adhering to the first rule of Fightclub.
Sent from my DROIDX using Tapatalk - 01-18-2012, 01:33 PM #9
Darn you TallyHo!!! I thought there would be some new or good news in here. Got my hopes up.
Anyone know anything more about the Verizon LTE Soak Test???? - 01-18-2012, 05:33 PM #10
- 01-18-2012, 07:20 PM #11
I received the same invitation, but after reading the requirements, I didn't fill out the form. One of the requirements was that the Xoom has a current Verizon 4G data plan. I don't have a data plan, so I will wait for the final release.
Sent from my 4G Xoom using Tapatalk.Motorola Droid Bionic 4g LTE - Motorola Xoom Tablet 4g LTE
And yes, the SIM card from the Bionic works great in the Xoom! - 01-19-2012, 12:16 PM #12
- 01-19-2012, 03:45 PM #13
I suspect we may hear something as soon as tomorrow about the Verizon Xoom's, since the WiFi Xooms deployment is fully under way. Keeping my sticky fingers crossed.
- 01-19-2012, 07:09 PM #14
- 01-19-2012, 07:22 PM #15
OK, I lied. I just went and checked my wifi Xoom, and the upgrade was ready to install. It took five minutes, and everything is working great!
And yes, the SIM card from the Bionic works great in the Xoom! - 01-19-2012, 07:49 PM #16
Verizon has to sign off on the 4G LTE Xoom update. So, it will take a bit longer...sadly. I wouldn't bet on seeing it this week or even next. It's not impossible, but, I'd not get my hopes up.
- 01-19-2012, 07:59 PM #17
- 01-19-2012, 08:00 PM #18
- 01-19-2012, 08:04 PM #19
- 01-19-2012, 08:05 PM #20
No, I don't think it'll take quite that long. As I just said, it's not the same as phone testing. They just have to verify that the new radio files don't break the network. Other than that, it's still a GED so, as long as it doesn't blow stuff up, it should get released fairly quickly.
- 01-19-2012, 08:07 PM #21
- 01-19-2012, 08:10 PM #22
Indeed. For now I went custom. I may never look back TBH. I got a chance to put my custom rom'd 4G LTE Xoom up against a WIFI OTA Xoom and quite frankly, the custom rom kicked the living heck out of the OTA rom. Not even a close contest. So while I'll update my stock rom with ICS when it's available, I may go back to my custom rom right after that.
- 01-19-2012, 08:14 PM #23
- 01-19-2012, 08:19 PM #24
Thanked by: - 01-19-2012, 08:39 PM #25
Having a 4G Xoom on Honeycomb and a wifi Xoom on ICS to compare side by side is pretty cool. The performance definitely seems a little snappier on ICS. The differences are not huge, but enough to know they are there.
Reply
I'm loving ICS on my phone, so looking forward to it on my Xoom; especially the data usage monitor which is a feature it should have had since day 1
