thelostsaint
Re: Motorola Xoom ICS update. FLASH WITH NO ROOT REQUIRED
silly question tho, how do you know if its the lte or wifi only?
well i just got mine today, and just learning everything and trying to catch up, but not sure if my xoom is wifi only, or LTE..
Okay...guess I was misunderstood the abbreviation. So..the OTG cable allows you to connect a USB flashdrive (where do you get one?) but whatever the connecting cable is called that allows you to connect the PC to the Xoom is my first issue since I can't do anything if the pc doesn't see my Xoom, right?
BasPilot just made an awesome guide for updating LTE Xooms. I added a link to the OP
MODS can you make this a sticky thread. I believe it to be of great use to the community
Threads with a link to an off-site guide aren't made sticky threads. If you'd like to make a quick write-up/guide in your own words for the thread, I'd be happy to review it for sticky-status.
