ragnarokx
Re: Motorola Xoom ICS update. FLASH WITH NO ROOT REQUIRED
For files too large to upload directly to the forums, try a site like multiupload.com or mirrorcreator.com instead.
All the external link was supply the file. I tried to upload the file but i kept getting an error probably becasue the file is 80mb. I did supply a step by step guide which i made by trail and error which reads:
Ok i think i figured it out. You cannot use the mircosd card slot to install the file.
you must use the otg cable.
And for anyone not familiar with recovery boot for the motorola Xoom here are the steps
1. Reboot press power and volume up button at same time.
2. At the motorola dual core screen>> press volume down ONCE after about 2 seconds you will see recover at the top left of screen.Press power button. If anything else comes up go back to step one and repeat. (Timing is wierd here)
3.We should be at the green android screen with the yellow warning sign. Press power and volume up keys once at the same time. This brings up the recovery menu. Use the Volume keys to move up and down and the power button to select.
I will add this to the OP and edit some things. Would that be enough
