How to Flash ICS for WiFi Xoom NO ROOT REQUIRED
danskkn
Worked perfectly.... I ordered the OTG cable from Amazon on Monday and it arrived on Tuesday. Downloaded file onto USB, followed directions and voila! ICS. When I first tried, I hit a button wrong and ended up stuck on Fastboot protocol support, but I just rebooted and started over....no problems at all. As I have this on my phone, I am familiar with it, but looking forward to seeing it in action on my Xoom!!! What are some things people are noticing with this update? (Non-soak testers of course!)
SamuriHL
2,084
81
I Just read threw all the posts, I am not rooted but I am unlocked, will it matter if I am Unlocked?
I tried to root before (a couple times actually) but literally gave up after 5 hours of frustration, using a Mac makes everything just that much harder to find guides and files.
Unlocked is no problem. You can install it so long as everything is still stock.
Sent from my Xoom using Tapatalk
DACNET
18
I am following the directions but keep receiving the E:Error in /tmp/sideload/package.zip
(Status 7)
Installation aborted.
Has anyone experienced this issue and have a resolution? I followed the earlier posted directions to re-download the zip file but keep having the same issue.
Help!
harold42483
523
29
(Status 7)
Help!
What kind of drive are you using to store the. Zip
DACNET
18
The Thumb Drive wasn't the problem.
(User Error!)
My problem was I flashed back to stock and didn't accept the 2 system updates. Once I did that I was able to apply the update from the USB drive.
GuyH
3
I have a UK wifi Xoom. Can I apply this update?
I tried to install on my stock Xoom and it gets so far as to say the package failed verification. I downloaded the zip from the link in this thread.
SamuriHL
2,084
81
No. US wifi xoom only. And the update is now being pushed ota.
Reactions: GuyH
gibby357
5
This is an extremely informative thread. Several people answering a lot of questions without being smart or condescending. I learned just by reading what an OTG is and what it is used for. I learned that when concerning the Xoom, not all memory sticks are created equal. I learned about different errors that I might receive and what they mean and how to correct them. Great information. One question that I have, since we are talking about WiFi Xoom, am I right in assuming that that includes the WiFi Family Edition?
Geezerb
280
4
18
Accepted the update, rebooted but got stuck on the exclamation icon screen. Reboots leave it on the Motorola screen. When I get home I will try the USB method. Mine is wifi only. Should I remove the SD card? Saw somewhere that it might interfere with the upgrade.
SamuriHL
2,084
81
No. That's a different piece of hardware and has its own rom, unfortunately. There has been a great deal of talk on other forums of not just when, but, if the FE is going to see ICS. I really don't have any knowledge of the device other than to tell you it's not the same as the original WIFI edition. Sorry to be the bearer of what is likely not going to be popular news.
SamuriHL
2,084
81
It won't hurt to remove it. That doesn't sound like a good situation, however. I hope you're able to get it sorted out.
Geezerb
280
4
18
I removed the SD card, rebooted & it came up with the old version. I tried forcing an update via settings but nothing. My guess is the update file was saved to the SD card. After an extensive search through my house I concluded that I don't have the correct cable to use above method. Will an external SD card & reader work?
SamuriHL
2,084
81
I doubt it but you never know. But the OTA update gets downloaded to /system/cache afaik, so, that wouldn't be on the sd card.
Geezerb
280
4
18
Don't want to be a nuisance, but is there any way to force the OTA DL again? Got all exited for nothing it seems:(
SamuriHL
2,084
81
I don't know. One would think doing a system update check would find it. If it's not, I really don't know what to tell you unfortunately.
Geezerb
280
4
18
Here is how to force the OTA DL:
Here is the fastest way to pull the OTA update from the sky.
Go to Setting –> Apps –> search for Google Services Framework –> Clear data –> Now go to About Tablet –> System Updates –> then hit Check Now button.
Reactions: SamuriHL
listloadrun
3
Thanks for the suggestion Geezerb but sadly that still shows no system update for me :( . Waiting for the OTG cable to be delivered (no one local had one) and was hoping that would do the trick. Ah well, something something patience, something something, right? :p
cbill
115
9
Listload: Did you reboot after clearing GS Framework? You might give that a try. Then do the System update check.
Good Luck!
fallingOutOfLoveWfithTech
