Results 1 to 7 of 7
- 09-04-2012, 09:06 AM
Thread Author #1
Xoom Issues - HELP
I have xoom running the ICS update. Since the update the device will lock up and screen will go black. Only solution is a soft reset, the factory reset.
Even is there is no additional apps installed it does this. It will work for 3 hours, a day, then I need to do it again.
Any ideas will be of great help! - 09-04-2012, 10:08 AM #2
Re: Xoom Issues - HELP
Why not move up to jellybean?
- 09-04-2012, 10:50 AM
Thread Author #3
There is no official 4.1 for the xoom to my knowledge, or is there?
I would like to avoid having to root and install a custom rom. - 09-04-2012, 08:41 PM #4
- 09-04-2012, 08:45 PM
Thread Author #5
wifi only...and Canada. No Jelly Bean here that I know of.
- 09-04-2012, 08:58 PM #6
Xoom wifi USA has jellybean update, I updated weeks ago.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums - 09-04-2012, 09:00 PM
Thread Author #7
ok....
Reply
