I got my SD card stuck in the cover hole how do I get it out
Printable View
I did that the first couple times, too. Try a pair of tweezers, very gently. Remind yourself: the SD card goes down into the front slot, facing you, and you have to push down a little to lock it into place/
This is really poor design. I'll get this happens to customers all the time.
Twezzers is the way to go... happened to me as well, doh!
If its dropped right down, power off, bend the tinyist of bends over on a paper clip to make a hook to pull it up to grasping reach . Good luckQuote:
Originally Posted by Elmo Firestone [Only registered and activated users can see links. Click Here To Register...]
