Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Alain LeBrasseur's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Xoom will not turn on
    Worked for me. Just cost me $6 for the screwdriver kit and 5 minutes of my time.
    Thanks.
  2. #27
    SpiralBorg's Avatar
    Posts
    Global Posts
    672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Rigelian View Post
    Press the power button while holding the volume up button down.
    Sent from my Xoom using Tapatalk
    Quote Originally Posted by kensteve51 View Post
    How timely, this just happened to me last night also. Your fix of taping volume and power button worked like a charm. Wonder what the root cause is?
    This happened to me once, thought my XOOM was done for! Though, I was used to holding and pressing the power button!:o
    Sent from my MZ604 using Android Central Forums
  3. #28
    zychang's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by smooches680 View Post
    I am in the same boat, I called Motorola but they was no help, it just seemed like after the ice cream update the Xoom stopped coming on and wont turn off but when I press the volume up and the power the screen comes half way on and shows the red Motorola symbol and that's it and it freezes there.
    Same here. It all starts to happen after the ice cream update. Did you ever figure out what's going on and how to fix it?
  4. #29
    SpiralBorg's Avatar
    Posts
    Global Posts
    672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I guess they fix it with the 4.1.2 update.
    Though, that was availible in select-countries..
  5. #30
    tclNJ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Now THAT did the trick... thanks! Only tricky part was that I had to create my own extra long spudger to get the back case off... but the Xoom works like a charm now.
    Quote Originally Posted by sandeepiitm View Post
    Try this...It worked for me..
    I let it charge until the LED went green and still no luck. Buy T5 Torx Screwdriver from lowes/Walmart and disconnect the two, copper battery connectors (Orange flat one) per these instructions Motorola Xoom Teardown - iFixit and separate the contacts with a piece of paper for about 30 seconds. This is the Xoom equivalent of a battery pull! Once back together, the Xoom booted right up. The whole process took less than 10 minutes
Tags for this Thread
