1. crypto#AC's Avatar
    I plugged my xoom into charge today (like I do everyday) and it refuses to charge! Has anyone else had this problem? I only 4% battery left! I've tried 3 different outlets.
    03-27-2011 10:23 PM
  2. siscim23's Avatar
    Have you tried turning it off then plugging it in? See if the charging LED lights up.
    03-27-2011 10:25 PM
  3. crypto#AC's Avatar
    Yes - it does not.
    03-27-2011 10:32 PM
  4. siscim23's Avatar
    Wow sorry to hear. Only thing I can think of is to try another charger to find out if it's your charger or Xoom.
    03-27-2011 10:41 PM
  5. effingpace's Avatar
    I've had this problem depending on the outlet im plugged into, I've noticed the the charger doesn't really get flush against the outlet. Try pushing it in more n see it if charges. This Has happened on multiple outlets for me
    03-27-2011 11:11 PM
  6. chaguewood's Avatar
    Mine did this yesterday and I freaked out. Luckily mine worked after trying a other outlet and now works in the previous one as well...seems like the charge port may be finicky. Keep trying and good luck
    03-27-2011 11:13 PM
  7. legendary1022's Avatar
    If all else fails just walk into a Verizon store and tell them what's going on. They are usually pretty helpful in getting a replacement device for you
    Sent from my Xoom
    03-28-2011 12:20 AM
  8. Super_Mario's Avatar
    You're using the charger and not trying to charge with the mini USB right?
    03-28-2011 12:29 AM
  9. jbdal's Avatar
    Mine is doing the same thing right now, it will not charge. The electrical charger fits loosely into the Xoom. I have tried mulitple outlets, I have tried switching it off and charging and it does not charge. It is at 4% as well. I have had it 40 days. Help, please if you know of a solution.
    06-19-2011 11:00 PM
  10. Major's Avatar
    Sounds like there's a batch of defective chargers out there. Best bet is to get a new one.
    06-20-2011 10:59 AM
  11. tagacapiz's Avatar
    to orig poster, bring it to seller.
    my charger picks outlets too.
    Sent from my Xoom using Tapatalk
    06-21-2011 04:26 PM
