Controlling the wireless connection.
Flipper
136
3
Hello all,:)
What I want to do is be able to switch between wireless connections whenever I want easier.
For instance: I use my hot-spot on my phone for my WiFi only Xoom. To help with the data limit I use occasionally the company wireless as well. Not all sites can be used on company wireless but usually everything I need. So I use the hot-spot for those other sites when at work.
I want one wireless connection to be more dominant over the other, so it automatically switches back n forth. EX: I will be next to my Xoom using my hot-spot and leave the room for a bit and it switches over to the company wireless. Then back in the room and I think I'm still hooked up to the hot-spot. NOT!
Any help would be great.
cloudsofmana
