Hey Everyone,
I need to be able to view PDFs with links to other PDFs and documents Locally. Basically our company would like to be able to hand our clients a tablet to be used similarly to that of an "owner's manuel".
I transfer the file folder, from a PC to the Xoom, which contains a number of subfolders that correspond to the page links located in the "master" PDF, and then in each subfolder there is one or more PDFs to that I want to be able to open up just by navigating through the "master" PDF. Now, with a couple of the apps I have tested already, I have been able to open up the "master" PDF and click the on the links (such as the table of contents) which takes me to the desired page in the "master PDF". My issue arises when I then attempt to open up the linked PDFs, they attempt to open through the browser (not what I want them to do anyway) but they don't open. I would like to be able to do all of this without the use of WIFI or the mobile network.
These are a few of the apps that I have tested from the android market without any luck,but I've also tested a number of other free pdf readers:
(all listed apps are the paid versions)
Adobe
ezPDF
BeamReader
RepliGo
DocumentsToGo Pro
OfficeSuite Pro
We have successfully done this on an iPad, but for numerous reasons, we would like to be able to achieve this with the xoom or another android tablet.
If you have any ideas for a solution I'd really appreciate it.
Thanks,
GTG
Adobe
ezPDF
BeamReader
RepliGo
DocumentsToGo Pro
OfficeSuite Pro
Thanks,
GTG
