Android Forums at AndroidCentral.com >  Motorola Android Tablets >  Motorola Xoom > Bluetooth to home Stereo WIRELESS How to / Product Review
    Thread Author   #1
Old 06-23-2011, 02:10 AM
Device(s): Xoom,WP7,MyTouch3Gslide
ROM/Kernel: Redenbacher
Activity: 0/20
I FINALLY made a video tonight to show you how I connect my Xoom ( and every single other device that I own ) to my home stereo via bluetooth.
It requires a product ( sony 2 way bluetooth adapter ) ( a little spendy , but clutch ). I do recommend the product, but have since moved on to a new soundbar which does similar. But the soundbar is far more expensive than this device...
I use it all the time, and if you don't have a way to wireless connect your Xoom ( or any other android, iphone, computer etc ) it works..
[Only registered users can view links. ]
[Only registered users can view links. ] by [Only registered users can view links. ], on Flickr
Also, I'd like to give a huge thanks to members and Android moderators for the love on my PS3 Controller - Xoom Video ( 22K views in 1 week ). and my [Only registered users can view links. ]
  #2
Old 06-23-2011, 10:04 AM
Device(s): DroidX2, Xoom
My Next Device: Galaxy Nexus
Activity: 3/20
There is a much cheaper way of doing this that also has other advantages. If you pick up a Plantronics Pulsar 260 BT headset with dongle. There is also an audio cable included that will allow you to plug into the audio input jack on your stereo (you may need an adapter depending on the type of input jack your stereo has).
You will also have the option of streaming music thru the dongle to the included headset while at the gym, etc. If your car stereo has an aux input jack you can plug the audio cable into it as well to stream music from your phone.
Here is a link to the Plantronics Pulsar 260, and the Sony 2 way Bluetooth device the OP was talking about.
Plantronics: [Only registered users can view links. ]
Sony: [Only registered users can view links. ]
    Thread Author   #3
Old 06-23-2011, 01:15 PM
Activity: 0/20
That's a pretty cool little option ( plantronics ) as well.
thanks live2ride883. weird in the amazon posting for the plantronics there's not much info in that thing..
how well does hte plantronics work with multiple devices ? do you have to resync it each time you change a device or is it in "always listenening" mode ?
  #4
Old 06-23-2011, 01:20 PM
Activity: 3/20
Like any other BT device once they are paired it will automatically connect. I have had mine for over a year and it works great. I actually used it in my car as I described in my earlier post before I purchased a head unit that has BT built in.
    Thread Author   #5
Old 06-23-2011, 01:30 PM
Activity: 0/20
Yeah, my head unit in my car also has built in bluetooth.
Regarding the pairing: Yes, once paired a device ( phone / tablet / etc ) will certainly remember the connection, but in the case of the sony adapter, it doesn't like to be switched back and forth between products. So if I go from my Xoom, then switch to WP7, it forces me to put the receiver back in discovery mode. Kind of like it "only remembers the last device connected to it" but forgets your 2nd device until you resync it...." it is a knock on the product, I'd have to test the plantronics version but it seems like a solid if not better option. I updated the writeup with a link to this discussion and the plantronics. thanks for the input.
In the end, it's great to be able to pump music and sound from video through the home stereo..
later, thanks.
Reply
Tags
bluetooth , bluetooth audio , home stereo , xoom
Thread Tools Search this Thread
Search this Thread:
Advanced Search
